907
| posted on 4/10/11 at 07:50 AM |
180mm Sander Polisher. Advice please.
Hi All,
I'm contemplating buying a sander/polisher, basically a low/variable speed angle grinder,
but can't make my mind up between a quality machine or a cheapy.
£50 (ish) buys a Silverline of eBay, or, do I lash out £200 (ish) on a Makita 9227CB ?
This won't be an every day tool, but on the other hand will get used for several hours when it is used.
Polishing aluminium would be it's main use, but no doubt "the boy" will borrow it for paintwork use.
What makes do body shops use?
Any one on here have any experience?
Makes, good or bad. Any to avoid?
Thanks in anticipation.
Paul G
| posted on 4/10/11 at 08:10 AM |
I have a Silverline one - it's a solid & well-made thing, with electronic speed control, pre-set max rpm, & stuff like that. Quite
heavy, but reasonably quiet.
I haven't used it for extended periods (I've hardly used it at all!) but it never sounds stressed when in use.
Shout if you want to give it a good looking over...
[Edited on 4/10/11 by David Jenkins]
steve m
| posted on 4/10/11 at 08:13 AM |
If you are doing this so you can polish your 7, forget it !
I bought a brand new silverline polisher to do my 7 and its way to big and unwieldly to do any real polishing
all the curves bends bars brackets etcget in the way, so you have to manually polish around them
once you have done that, there isnt much of the car left to do !!
I think my best polishing was done with a drill and buffer wheel
| posted on 4/10/11 at 08:17 AM |
I have a Silverline polisher that seems to have been borrowed and abused by every man and his dog and it's never let me down. For occasional
use (rather than, say, in a paint shop) I don't think you can go too far wrong with these.
cliftyhanger
| posted on 4/10/11 at 09:18 AM |
agreed, got one of the orange ones, not heavy use but polished a few cars, several times, plus a couple of reprays have been compounded with it.
Bluemoon
| posted on 4/10/11 at 09:37 AM |
I have a Silverline one... It's a heavy machine and one of the better "cheap" polishers. Fitted with proper mops (you can get a cone
for them) for polishing metal apparently some professionals use them this way as they are a lot cheaper than a "professional one"; but
they will ware out if you use it a lot/use a lot of pressure. If you use the cone and mop you will ware out the bearings quicker as they are not
designed for side loading (but that's what I am doing, not enough polishing yet to say how long it will last)...
Also don't choose the largest mops but go for smaller ones to keep the load down on the bearing if using a cone.
Dan
907
| posted on 4/10/11 at 10:54 AM |
Thanks for all the replies so far.
David. I'D LOVE TO,
but with the price of fuel I just might as well just buy one.
Interesting about the side loading of the bearings.
As well as the normal discs and sponges I was thinking of these.
  polisher tools
I already have a bench polisher that takes up to 10" mops, which is fine for bits that come off the car.
Even mudguards are possible on this although a bit of a hand full.
Thanks again,
Paul G
| posted on 4/10/11 at 11:12 AM |
You can get polishing heads to fit on variable speed rotary sanders which are a lot smaller than the angle grinder type polisher and easier to
manoeuvre.
Bluemoon
| posted on 4/10/11 at 12:08 PM |
^^ Those mops are I think the same size as mine (not sure, just moved house and no chance of checking at the moment!)... The poblem is the cone sticks
out a lot, I may get mine machined down a bit (there is lot's of spare meat on the hex part) this would help reduce the side load on the
bearings..
[Edited on 4/10/11 by Bluemoon]
NS Dev
| posted on 4/10/11 at 03:46 PM |
we use a cheapy silverline one and its done 3 years hard labour now!! It makes an awful din like a straight cut box, but then it always has done and
has never got worse!
Chippy
| posted on 4/10/11 at 04:26 PM |
I have a Silverline, it has been used to polish the F/G hulls of three boats, mine and two, (can I borrows), so gets used all day more or less on each
one. I have also used it to polish the cars, (3 off), on an infrequent basis. So far no sign of it getting worn or tired, :-) HTH Ray
907
| posted on 5/10/11 at 08:38 AM |
I'm impressed (but then I'm easily impressed ) with the feedback on this tool.
My one concern is the "awful din" that NS Dev refers to.
I have a very good relationship with my neighbors and long may that continue.
Paul G
Bluemoon
| posted on 5/10/11 at 09:58 AM |
Yep mine is also noisy not sure how much better the expensive ones are in this department.. I think there are some very good US make machines but will
cost £££...
| posted on 5/10/11 at 03:02 PM |
Sorry Paul, I led you astray... mine is a Draper Expert Angle
Polisher, which I bought from JustOffBase (local to us, based in Bury St Edmunds). Mine was a bit cheaper at £82 though (inflation plus higher
VAT) - and it was a Christmas prezzie!
It's a formidable beast, and relatively quiet. The offer to take a look at it still stands...
cheers,
| posted on 5/10/11 at 06:55 PM |
Thanks David but I have bitten the bullet and gone for the Makita.
I found it on special offer for £189.95 at Axminster this morning.
He doesn't know it yet but the tax man will make a contribution towards it as well.
There is the odd benefit to being self employed.
Thanks to everyone for their contributions to this thread.
Paul G
907
| posted on 10/10/11 at 04:46 PM |
Hi All.
Just to put this thread to bed so to speak the Makita arrived today.
I was expecting it to be bigger. It's sort of half way between a 7" grinder and a 4.5" grinder,
and quiet, I'll say it's quiet. It was easy to talk to the Missus while I was showing her how to use it.
Well, I can live in hope can't I.
Thanks everyone.
Paul G
NS Dev
| posted on 10/10/11 at 05:59 PM |
sounds a good bit of kit.
When old noisy dies we'll go for one of those.
The silverline is bigger, sort of between 7" and 9" grinder
Neville Jones
| posted on 10/10/11 at 06:12 PM |
I've had a Makita for 22years. One set of brushes about four years ago, and it's used every week and more. You can't go wrong.
Everything else is Hitachi, same reliability.
Nev.
NS Dev
| posted on 10/10/11 at 06:18 PM |
Going off track now, but we also use makita or hitachi for all our grinders etc (the polisher is the only real cheapy in there) and have been great
until lately, Hitachi seem to have gone a bit cheap with their smaller grinders.
I have 5 4.5" hitachi grinders, all the same model, and the switches on 2 have broken and the com lost a segment on the oldest one.
On the plus side, they are very nicely made from a repair point of view, dead easy to fix the switches, a slightly modified toggle switch slots
straight in inside!
907
| posted on 11/10/11 at 01:27 PM |
I've taken a photo for size comparison.
  size comparison
Paul G
Bluemoon
| posted on 11/10/11 at 02:33 PM |
Looks good, I expect it will be the better buy in the long run, if a few more ££.
