Author: Subject: Radiused Edges
posted on 16/10/11 at 07:18 PM Reply With Quote
Radiused Edges
Is there a specific tool for putting a neat radius on the edge of steel?
Or is it just a case of doing your best with a Dremel and hoping the finished product looks good?
It's Evolution Baby!
MakeEverything
posted on 16/10/11 at 07:27 PM Reply With Quote
Kindest Regards,
Richard.
posted on 16/10/11 at 07:34 PM Reply With Quote
Confused but excited.
posted on 16/10/11 at 07:57 PM Reply With Quote
How thick is the metal?
Can you not draw file it? Then finish with emery cloth.
[Edited on 16/10/11 by Confused but excited.]
Fred W B
posted on 16/10/11 at 07:58 PM Reply With Quote
What thickness materail and how big a piece? How good (accurate, uniform) does it have to be?
A dremel in my opion is the wrong tool - too small and difficult to control. You will have the most control with a hand file.
Otherwise run a flex back sanding disc on an angle grinder along the edge.
Fred W B
Edit - Writing as above was posted, we agree
[Edited on 16/10/11 by Fred W B]
posted on 16/10/11 at 08:03 PM Reply With Quote
Cheers guys!
mark chandler
posted on 16/10/11 at 08:24 PM Reply With Quote
I have it on good authority that a decent putting on file can develop a very nice curved edge Not tried it myself though.
Fred W B
posted on 16/10/11 at 08:29 PM Reply With Quote
The right tool is as below, you can see some dicussion here
Fred W B
Rod Ends
posted on 16/10/11 at 09:06 PM Reply With Quote
If it's sheet metal, use a wired or beaded edge:
foskid
posted on 16/10/11 at 10:29 PM Reply With Quote
You can try using a Dynafile I get excellent results with them. Available in air operated and in elect versions.
Have look at Dynafile / Dynabrade Mini Air Belt File Sander Linisher | eBay
Regards,
John
