marktigere1
| posted on 10/8/04 at 09:14 AM |
Cutting method?
Searched but cannot find the most accurate method of cutting the chassis tubes.
Best method/suggestions?
I was thinking of using an angle grinder attached to a stand eg. as sold by Screwfix? then a file etc.
If a bolt is stuck force it.
If it breaks, it needed replacing anyway!!!
(My Dad 1991)
I love speed :-P
| posted on 10/8/04 at 09:33 AM |
that what we used, and it worked very well, but watch your fingers, as it can take them off dead easy, but other than that they are gr8, however you r
best using a 5" of greater angle grinder with flat discs
Don't Steal
The Government doesn’t like the competition
type 907
| posted on 10/8/04 at 10:42 AM |
Hi
I bought one of those horizontal band saws, not locost I know, for £170.
The idea was to sell it afterwards, but it's soooo handy I'v kept it.
Cuts dead square, set it at any angle, even cuts compound angles. Just cut & tack.
Anyone wants to buy a file? Very little use!!!
Paul G
Too much is just enough
garage19
| posted on 10/8/04 at 10:50 AM |
I'm with Paul on the band saw. Great bit of kit... even better if you can pop round and use someone elses!
If you mark the steel up first it would prob only take you 15 mins to cut.
DC
liam.mccaffrey
| posted on 10/8/04 at 10:55 AM |
i am going to use a 230 mm metal cutting grinding disc in a cheapo compound mitre chop saw for a locost option, or i will get an 8" slitting saw
blade this will be better probably but more expensive
Build Blog
Build Photo Album
marktigere1
| posted on 10/8/04 at 11:25 AM |
Thanks for the replies
(My Dad 1991)
Bob C
| posted on 10/8/04 at 11:27 AM |
Real men use a 12" hacksaw & a protractor setsquare thing.
I suspect it's actually quicker than the powered alternatives after all the setting up is gone through!
Bob C
RPS
| posted on 10/8/04 at 02:34 PM |
I've just completed my chassis, and cut it all by hand with a good quality hacksaw. Glad I did it that way in the end, it improved my skills
and saved money. I only used two hacksaw blades in the whole process!
RPS
jack trolley
| posted on 10/8/04 at 07:17 PM |
Screwfix now do a Mini Cut Off Saw for £39.99:
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=26358&ts=65123
RoadkillUK
| posted on 10/8/04 at 07:22 PM |
Do it by hand.
P.S. My brother did most of the cutting
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
crbrlfrost
| posted on 10/8/04 at 10:37 PM |
I have to say the horizontal bandsaw is pretty nice. Had my brother do the cutting while I did the tacking and welding so we were working at a similar
pace. By the time I had set up and tacked one section, he had cut and was setting up the next. And he only lost three fingers. Cheers!
Cita
| posted on 11/8/04 at 03:03 PM |
real men do it with their hands (and a hacksaw)
leto
| posted on 12/8/04 at 11:00 AM |
We use a angle grinder on a stand, mounted on parts from a couple of tile cutters. Would have prefer a band saw but it was out of budget. There is a
“protractor” drawn on the board, a 750mm square with one corner at the support near the cutter. From a spread sheath table the desired angle is
transformed to a point on the 750mm square. The resolution is better than 0.1 degree. The 3-D- members, like LA/LB, is somewhat trickier, there are
drawings in an other thread some were.
  Homemade pipe cuter
REAL, real men never spill their sweat unless it makes them smile
“I'm gonna ride around in style
I'm gonna drive everybody wild
'Cause I'll have the only one there is a round”. (J. Cash)
marktigere1
| posted on 12/8/04 at 01:38 PM |
Thanks for all the responses
Didn't know there were so many 'Real Men' on the forum?
Mark
(My Dad 1991)
