alan87
posted on 4/1/12 at 10:19 PM |
RivNut supplier
Evening gents,
I have had to take the side pod of my fury to replace a sheared exhaust mount. However instead of the melee of nuts, bolts and self tappers it is
currently held on with, I would like to change it to Rivnuts for future ease of removal.
Couple of things really, I'm looking at getting the tool from here http://www.powerfuluk.com/categorylist/other-rivnut-tools-and-rivnuts/
I know a few people have purchased the tool, so that's fine. But does anybody know if the rivnut packages are reasonable quality. I'm
planning on using 5mm nuts.
Finally if anyone has any pointers for attaching Rivnuts through GRP they woul be gratefully appreciated.
Regards Alan
P.s apologies for any speeling errors, iPhone isn't the easiest to post on!
[Edited on 4/1/12 by alan87]
The Venom Project
| posted on 4/1/12 at 10:25 PM |
This is who I use:
http://www.bapp.co.uk/contact
They are a Yorkshire company but you can order with them for delivery.
It's not that i'm lazy, it's that I just don't care.....
gazza285
| posted on 4/1/12 at 10:33 PM |
I can second BAPP as a great company, but whilst working in Southampton I used these chaps;
Thunderbolts
Fantastic name as well.
Bluemoon
| posted on 5/1/12 at 10:40 AM |
You need special rive-nuts for GRP else they will crack the panel.. I would recommend taking to primary fasteners...
http://www.prifast.co.uk/ very hep lull on the phone and not that expensive..
The Venom Project
| posted on 5/1/12 at 11:34 AM |
What I did for removing the rear wings on my MNR was to use Hank Bushes, these are like a nut with a shoulder, ideally you would use a ball pein
hammer and hammer them into some alloy sheet. They seem to grip Ali very well and if you fit them into wide, load spreading panels of Ali sheet, you
can then drill a small hole on the GRP for the screw.
Another way of doing it might be to weld a plated nut onto a stainless sheet and then use that instead.
The only thing I would say with Rivnuts is, once they slip its a Bugger trying to get anything out. I put one in my swingarm, its slipped and now has
had the bolt angle ground off.
Generally speaking,if you can get to the otherwise of the mount, use an alternative to Rivnuts. That's just my personal opinion, but if you
speak to a fabricator, I'm pretty sure they will tell you this too.
mad-butcher
| posted on 5/1/12 at 08:08 PM |
this is the way I attatched the wings to the side panels on the MK. 25mm x 6mm flat bar tapped for bolt and pop riveted to panel
[img]
[/img]
[img]
[/img]
[Edited on 5/1/12 by mad-butcher]
alan87
| posted on 6/1/12 at 10:22 PM |
Thanks for the replies. I understand that once the Rivnuts slip they are a bugger. I had planned on using some araldite or similar to give them some
extra hold.
Will try a couple of the links aswel, although have found namrick also sell them. So may just stock up on a whole load of fasteners at once.
