dave
posted on 9/1/12 at 11:14 PM |
Grinding welds
I have been filling up the old rivet holes in the chassis and now I need to grind them down. I have a 80 grit flap wheel but its a bit rough, is there
something else I can use?
loggyboy
posted on 9/1/12 at 11:19 PM |
Metal file?
Simon
posted on 9/1/12 at 11:30 PM |
B&D Powerfile. Various grades of belt available from Screwfix etc. Shop around for best price - varies wildly!
Simon
owelly
posted on 9/1/12 at 11:48 PM |
Flap disc in the angry grinder. Go nice and gentle and you can polish steel.
http://www.ppcmag.co.uk
Andi
posted on 9/1/12 at 11:54 PM |
+1 for the angry flap disc.. Gives a mirror like shine to the roughest of steels
NigeEss
posted on 10/1/12 at 12:01 AM |
+2
owelly
posted on 10/1/12 at 02:17 AM |
This was a bit of a rush job but you get the idea.
[Edited on 10/1/12 by owelly]
MikeFellows
posted on 10/1/12 at 08:47 AM |
you must have the patience of a saint how long did that take
good work though
owelly
posted on 10/1/12 at 09:01 AM |
Sections sliced with thin cutting disc using paper template so took about 20 minutes. Setting up, tacking then MIG welding took about an hour and
about 10 minutes to whiz over it with the flappy disc.
onenastyviper
posted on 10/1/12 at 10:19 AM |
Simon
Just make sure you thoroughly clean the metal swarf otherwise on day it will flash over and die - did on me
Angry Grinders seem to be better designed to handle the dust - the powerfile seemed to suck it in through the drive sprocket.
designer
posted on 10/1/12 at 11:13 AM |
Another for the flap disc.
posted on 10/1/12 at 05:15 PM |
I use a flexible backing disc with 80 grit fibre disc on the grinder, it works out a lot cheaper than flap discs if you are doing enough and you can
get discs in any grade.
Simon
posted on 10/1/12 at 08:35 PM |
Simon
Did you leave the dust collector on, b&d recommneded 20 years ago that if using on metal, just to leave the back open without the collector.
Broken dozens of them meself. Make sure if you wear out the arm (bearings in wheel go) that you hang onto it, and when grinder dies under warranty,
send arm back to get replaced too.
Simon
Neville Jones
posted on 11/1/12 at 11:18 AM |
Try one of the combined sanding and polishing discs. You should be able to get to a near miror finish.
