posted on 19/1/12 at 11:46 AM |
Anyone tried the Clarke 230v Impact Wrench ?
One of the battery packs for my much used and abused Macallister 14.4v cordless impact wrench is getting tired (my own fault I forgot to charge it
after use) so I am looking at buying a replacement wrench.
The Clarke Electric Impact Wrench CEW1000 230v wrench has a good spec and decent price., I have a friend with a Makita 230v wrench for motor cycle
work and he swears by it.
As for air impact wrenches and air ratchets --- been there got the T shirt and I don't want to go back.
jossey
posted on 19/1/12 at 11:52 AM |
its a good toy i had one till i got my new compressor and gave it to a friend.
Only let me down when the garage over tightened my wheel nuts.
David Johnson
ashg
posted on 19/1/12 at 12:16 PM |
i have got a bosch cordless one GDS18V will do 220nm. the only bolt so far that i found that i wouldn't undo was one of the rear sub frame
bolts on the mx5 when i broke it to build the exocet. it has no bother taking off stupid tight wheel bolts. have also undone crank end bolts and
camshaft bolts with it too.
[Edited on 19/1/2012 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
v8kid
posted on 19/1/12 at 12:23 PM |
Have you thought about replacing the cells? They are quite cheap although there is a specific size for power tools - blessed if I can remember now but
google is your pal.
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
jossey
posted on 19/1/12 at 01:22 PM |
i had a bosch drill which stopped holding charge.
Someone showed me a post about recharging the cells with higher voltage. now the old battery works as well as the new one.
David Johnson
Mr C
posted on 19/1/12 at 04:20 PM |
It quite brutal as the torque is not adjustable, either on or off. Its well made,very robust. I bought mine for undoing the sierra driveshft bolts
with the shafts etc off the car, it was a walk in the park once I found a socket up to the job. Use proper impact sockets as the usual sockets will
flake at best or fracture. I use for undoing, but not for doing up because of the torque not being adjustable and the danger of doing damage by
quesstimating. Though mine gets minimal use it is invaluable for the odd job which would otherwise have me cursing and swearing for hours.
Girl walks into a bar and asks for a double entendre, so the barman gave her one
posted on 19/1/12 at 04:42 PM |
Out of interest why not, is it just the portability aspect?
posted on 19/1/12 at 05:08 PM |
Hose gets in the way , compressor noise also electric ones are smaller, although it lacks the punch of bigger types the MacAllister 14.4v
cordless one is particularly easy to get into tight spaces
[Edited on 19/1/12 by britishtrident]
aka_shortie
posted on 4/4/12 at 08:06 PM |
Been thinking of one of these myself unless anyone has any other suggestions?
Anyone found replacement batteries?
