Author: Subject: Technique for drilling out a carb Jet?
Ivan
posted on 25/1/12 at 04:29 PM Reply With Quote
I think I need to increase the jet size of my Holly accelerator pump jets from .025" to .032" (or possibly bigger) because of a massive bog and 2 X backfires before the engine accelerates like hell when you floor the accelerator when cruising at lowish speed.
Any technique I should be aware of before drilling to make sure the hole is good and round - I guess the highest speed and ultra slow feed rate with lubrication is the secret but am I right.
The reason I am drilling and not buying a bigger jet is that although standard jets are available in RSA larger ones are not so if drilling doesn't work I can always go back to standard for about 2 Pounds a jet.
tegwin
posted on 25/1/12 at 04:40 PM Reply With Quote
Do you have a lathe?
With a drill that small it would be the easiest option.... But yes, high RMPS slow feed and a suitable lube for the material
www.verticalhorizonsmedia.tv
posted on 25/1/12 at 05:13 PM Reply With Quote
I drill out LPG nozzles from 1.2mm upwards.
A simple Jewellers Spiral "Push Drill" (sometimes called an Archimedes drill) will do the job with sufficient accuracy but it will take about 30 minutes for each jet to drill through. A Dremmel type tool will also do the job but will require and patience to produce an accurate hole.
Fred W B
posted on 25/1/12 at 06:09 PM Reply With Quote
To do jet drilling at the track we always just used to hold a loose chuck with the drill bit in it in the hand and turn the jet onto the drill with the other hand. We may have held the jet in a tap holder. The brass (at least with the jets we used) was soft enough.
It's not like the hole needs to be a precision fit.
Fred W B
[Edited on 25/1/12 by Fred W B]
jacko
posted on 25/1/12 at 07:04 PM Reply With Quote
Put the drill bit in a vice and twist the jet by hand
A pin vice and a steady hand works perfectly.
posted on 25/1/12 at 07:43 PM Reply With Quote
i just used a normal drill bit, a cordless drill, and did them by hand. Took a few seconds on each.
Ivan
posted on 26/1/12 at 03:16 AM Reply With Quote
Thanks all for advice - seems like slow feed is the answer otherwise any speed from dead slow to fast works. Now to decide what size to drill them. I think I will go up in 10% increments - i.e. approximately 20% increases in flow.
Fred W B
posted on 26/1/12 at 06:02 AM Reply With Quote
If you go too big you can close them up again with solder and redrill
Fred W B
jossey
posted on 26/1/12 at 07:59 AM Reply With Quote
Really simple
Take carbs apart. Take to a bike shop.... Give them £20-25 and let them do it. Pick up later all done :-)
David Johnson
sprouts-car
posted on 26/1/12 at 09:38 AM Reply With Quote
Thats not the locost way!
Build blog
posted on 26/1/12 at 09:56 AM Reply With Quote
I did the same but with an Aldi Dremel type tool. If I run a drill that small at a slow speed it will just snap off guaranteed.
