I love speed :-P
posted on 22/8/04 at 03:18 PM |
Welder Help
THe Chassis it tacked together, and now its ready to be fully welded, but thw mig welder is broken
When the trigger is pulled the wire come outs, but in a stop start fashion, we have tried mostthings, but any help would be greatly appricated, as
2morrow, is going 2 pour down, and need 2 weld, while it is still nice
Thanks very much
Philip Moreton
Don't Steal
The Government doesn’t like the competition
white130d
| posted on 22/8/04 at 03:28 PM |
Wire
Try a new spool of wire. If the existing one has become unwound or is a little "sticky" from sitting around it could cause it to bind in
the gun. Also, I am sure you already checked the roller tension on the feed....
David.
and if all else fails, just send me the 11 body
"There's only 2 things that money can't buy, and that's true love and home grown tomatos" Guy Clark
I love speed :-P
| posted on 22/8/04 at 03:35 PM |
tried all thats, b4, but didnt make a difference
btw the welder is the migmate 105 t
Don't Steal
I love speed :-P
| posted on 22/8/04 at 03:36 PM |
the way i am feelin at the min, if u can collect u can have, with the nackered welder
Don't Steal
Wadders
| posted on 22/8/04 at 03:46 PM |
Try unscrewing the tip, and see if it feeds ok, if so replace the tip. If not it could be the liner thats knackered. can you disconnect the torch lead
from the welder.
if you can, try feeding without it on, if the rollers are pushing it out ok it must be something after them thats causing the sticking.
Other than that, as suggested it could be a bad batch of wire.
Silly thought but the welders not set to spot weld is it?
Good luck Al.
I love speed :-P
| posted on 22/8/04 at 03:49 PM |
from the welder.
Good luck Al.
We have tried all that/changed the wire etc but still no differnce, and it hasnt got a setting to spot weld
Don't Steal
Ben_Copeland
| posted on 22/8/04 at 05:49 PM |
We borrowed an old MIG a while ago, it used to do this after about 30mins of use... narrowed down to the electronics i'm affraid.... cant
remember the exact details of it.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
| posted on 22/8/04 at 05:58 PM |
I had that with a sip 130 autoplus.
It was a long time ago but the problem was a transistor on the feed controller board. It was fixed under warranty and only took minutes.
Mark Allanson
| posted on 22/8/04 at 07:30 PM |
Have you tried the tension on the wire spool, not the feed but the actual spool. If it is too tight you get drag and the wire can burn back into the
tip, too loose and you get flywheel effect (similar to what you are complaining of). The wire is pulled by the feed rollers, but the spool turns
freely and overtakes the rollers, then slows again and the cycle repeats - snatch & pull.
If you are using a spool which is too big for the welder, the problem is amplified - my clark 140 will take a 15kg reel, but the feed cannot cope with
it.
The other favorite is a partially blocked liner, metal dust builds up and prevents smooth feed. A good blow out with an airline cures this.
splitrivet
| posted on 23/8/04 at 11:46 AM |
Whereabouts in Stoke are you Phil could possibly pop round and take a look at it for yer.
Bob
I love speed :-P
| posted on 23/8/04 at 01:57 PM |
Bob
Thank you, however, we have taken it, to someone, who. said, they will look at it for us, but, it looks like, it will b easier, to get a new one
Don't Steal
Ben_Copeland
| posted on 23/8/04 at 02:35 PM |
Possible World Record contender for number of comma's used
Ben
Roadster
I love speed :-P
| posted on 23/8/04 at 05:19 PM |
i'm pissed of, so leave me alone , just got a new welder, and that doesnt work
Don't Steal
Ben_Copeland
| posted on 23/8/04 at 06:19 PM |
Whats wrong with the new one then ??? You sure you turned it on
Ben
Roadster
I love speed :-P
| posted on 23/8/04 at 06:25 PM |
F*** off
p.s. it was turned on, it sounds like, its shorting out inside
Don't Steal
