I love speed :-P
| posted on 24/8/04 at 07:39 PM |
Machine mart Air shears
To day tring 2 cut my steel floor out, using these shears
http://www.machinemart.co.uk/product.asp?p=000310940
got into it about 18 inches, and then cutter snapped of, to it back, swopped it for another one, and some problem again, anyone else, had this
problem, or anything simliar?
Thanks Philip >not having much luck with tools< Moreton
[Edited on 24/8/2004 by I love speed :-P]
Don't Steal
The Government doesn’t like the competition
| posted on 24/8/04 at 07:44 PM |
I had a manual version of these - they will snap the blade if:-
a. the material is too thick/hard
b. you try to turn a corner
They only do straight lines, or incredibly gentle turns. If you want to do twisty bits then you need a nibbler - but they're not so good at
straight lines, at least without having a straight-edge to follow.
mangogrooveworkshop
| posted on 24/8/04 at 07:47 PM |
your expecting a bit much cutting steel with those. I use them to cut ali and they are great.
For steel you should be using the saw ccs185m
or one of these Clarke CPS125 2mm Sheet/8mm dia. bar 051210072 £45.95 £53.99 add
Clarke CPS150 3mm Sheet/8mm dia. bar 051210073 £49.95 £58.69 add
Clarke CPS200 4mm Sheet/12mm dia. bar 051210074 £69.95 £82.19 add
http://www.machinemart.co.uk/product.asp?p=051210074&r=2044&g=106
[Edited on 24-8-04 by mangogrooveworkshop]
| posted on 24/8/04 at 08:09 PM |
get a plasma cutter! i did, £500 and i only used it once... big waste of dough. i ended up using a jigsaw for many bits, it works wonders with the
right blade. I wish id never bought the cutter, cos i also got a compressor that hasnt been used since...
I love speed :-P
| posted on 24/8/04 at 08:19 PM |
Thanks what i thought, but b4 we brought it, we took in a sample of the floor, and they said it would cut it no problem
Don't Steal
wilkingj
| posted on 24/8/04 at 09:35 PM |
Ohhh... Hmmm I was about to get a pair of those.
I must admit that I was concerned by the breakage above. However, I was only thinking of one for the Ally bits, although I have a set of Aviation
tinsnips red / green / yellow ones for that.
I have thought about a plasma cutter, but its the price that puts me off.
I have a 14CFM compressor, I dont use it a huge amount, but wouldnt be without it. I have a small range of air tools, and they are pretty good on the
whole.
I suffered with Guillian Barre Syndrome 9 years ago, and have no stamina now, hence lots of physical work absolutely drains me.
www.gbs.org.uk - Read the Guestbook if you want to know what it can do to you. I got off fairly lightly with a 90% recovery
I got it by breathing in Algae (lots of it) blown up with my pressure washer. A simple paper mask could have prevented it.
Air tools help a lot, and the welder has saved me more than it has cost!.
These tools are cheap and cheerful (Sorry.. Value / budget). For the weekend mechanic, I find them more than adequate. ie Dont push them too hard!
Best Regards
Geoffw
Best Regards
Geoff
http://www.v8viento.co.uk
niceperson709
| posted on 24/8/04 at 10:05 PM |
Hi mate
What I did was get my local sheet metal place to cut out the floor with their gilotine only a couple of bucks per cut , that gave me the basic
outline and all i had to do was cut outs for the transmission, with my trusty angle grinder. a hint for cutting longer cuts with an angle grinder is
to clamp/ tack weld some steel strip to provide a guide oh and don't put to much preasure on the grinder.
best wishes
Iain
splitrivet
| posted on 25/8/04 at 01:37 PM |
Ive had one of those for years and aint busted a blade yet,I think 16's gauge is right on the limit for em tho plus you need a large compressor
at least 12 cfm those little aldi £60 jobbies run out of puff after a 6 inch cut.
The other thing is let it do the work and dont force it.
In saying this I'm bound to bust the blade the next time I use it.
As Ian says tho best bet is to take your steel round to a local tin basher and let them guillotine it
Bob
