theconrodkid
| posted on 24/3/12 at 06:40 PM |
pillar drill switch
as it was a nice day,i decided to fix my pillar drill,the switch has had it,its a 2 button jobbie with 4 terminals on the back.
could i get away with a simple dpdt toggle switch as mounting a non original switch would be a bit difficult.
also,where would i get such a switch,flea bay only brings up cheapo switches that dont look like they would handle the power
who cares who wins
pass the pork pies
slingshot2000
| posted on 24/3/12 at 07:00 PM |
What make is the drill ? It should probably be a 'zero volt' switch, ie if it loose power for any reason it need to be switched ON again.
That is, it will now restart when power is restored.
What wattage is the motor? Your local Machine Mart should be able to fix you up with something.
Regards
Jon
r1_pete
| posted on 24/3/12 at 07:05 PM |
I used a single speed car heater motor rocker switch in my last pillar drill for about 12 years, 1/4 hp motor, in the end it was the table arm which
gave out due to mis use.
| posted on 24/3/12 at 07:58 PM |
It is a zero volts switch for good safety reasons
MACHINE TOOL DRILL PRESS SWITCH PUSH BUTTON LATCHING MOTOR STARTER KAO-5BOX | eBay
slingshot2000
| posted on 24/3/12 at 08:20 PM |
Exactly !
SteveWalker
| posted on 24/3/12 at 09:32 PM |
Buy a proper zero volt switch or make your own. If you've got the bits lying around then you need a push to make switch that operates a double
pole relay. One pole switches the drill on, while the other parallels the start button, to keep the relay energised. The power to the start button is
fed via a push to break switch, so pressing this (or a power failure) de-energises the relay and stops everything. Check you relay rating is
sufficient for the motor.
paulf
| posted on 24/3/12 at 10:16 PM |
I would have a look at Maplins for a switch, I don't think that a zero volt switch is that important on a home use drilling machine, my old
Fobco drill does not have a no volt switch and many older industrial machines didn't.
Paul
theconrodkid
| posted on 25/3/12 at 05:39 AM |
thanks for the replies peeps,ill get the proper one
who cares who wins
pass the pork pies
