doughie
posted on 9/4/12 at 03:17 PM |
Tunnel tactics!!
Just about to start buildin the tunnel (will be using the 1300 x-flow and either 4 speed or type 9)
those of you with a standard book locost on the road - is there anything i should take into account?
(mods for diff/ gearbox clearance etc)
adithorp
posted on 9/4/12 at 03:56 PM |
When I saw the thread title I thought my answer would be...
Take out the ear plugs, drop it down a couple of gears and floor the loud pedal.
...but I guess thats a different sort of tunnel. Sorry can't realy help.
http://jpsc.org.uk/forum/
JeffHs
posted on 9/4/12 at 04:04 PM |
Mine is a standard live axle book chassis with Pinto and RS bellhousing on 4 speed box. Originally I put the engine where the book says but eventually
I chopped out the bottom of the tunnel at the front end and moved the engine and box about 6 inches further back. I rebuilt the tunnel by plating it
with 18 gauge steel.
It gave me a near perfect 50:50 weight distribution at SVA, removed the need for a gear lever extension and made routing the steering column past the
alternator a doddle - I manged to use the original big Pinto alternator.
Only disdavantages I can see is a slightly compromised footwell but my size 9s fit ok; I had to use an expensive angle drive for the speedo
(electronics would be simpler) and it's a real pain to fit a clutch cable after the gearbox is installed, but doable.
doughie
posted on 12/4/12 at 06:38 AM |
Thanks for your replies
Cheers JeffHs - have opted to widen the drivers side a little (20mm) and see where the engine/ gearbox will sit...
Adithorpe - hope to be asking about that some time, but it won't be soon... ![](/images//smilies/bigsmile.gif)
