liam.mccaffrey
| posted on 30/8/04 at 08:23 AM |
DIY argoshield
could you use a pub co2 bottle and a pure argon bottle both with twin dial pressure regulators to mix your own argo shield, this would cover al bases
as you would have pure co2 pure argon and argoshield?
Build Blog
Build Photo Album
| posted on 30/8/04 at 08:43 AM |
I asked on a welding site if it would be possible using a 'T' piece in the pipe but I never got a reply. They obviously didn't take
me seriously. I wanted more of an either or, rather than a mix which I cannot see why it shouldn't work. You would have to be precise with the
pressures to get your 5% or whatever mix but with some fiddling it sounds possible. It's one of those things you have to try for yourself or
you'll never know.
liam.mccaffrey
| posted on 30/8/04 at 09:18 AM |
exactly, i have most of the equipment any way so i'll suck it and see. all you would have to do is proportion outlet pressures in the ratio of
% mix you want,
Build Blog
Build Photo Album
type 907
| posted on 30/8/04 at 10:14 AM |
Flow meters
Hi
Even using two stage regulators it would be difficult to set an exact mix.
On my TIG set I use flow meters (see pic) which have a rising ball inside a perspex tube. These give a spot on flow rate.
Set one to 2 L/min and the other to 8 L/min and you would have a 20% mix.
Not sure about back flow when you stop welding; perhaps non return valves in each line.
Paul G
Too much is just enough
undecided
| posted on 30/8/04 at 10:16 AM |
Why mess about when air products will rent you a small bottle for home use "cougar 5" they are cheaper than BOC too.
Gas bottles are accidents waiting to happen...ever seen one go off?.....treat them like compressed air.......handy but still wants to kill the prick
who messes with it
mad4x4
| posted on 30/8/04 at 11:51 AM |
Why bother with aroshield unless you are doing a lot of welding
CO" welding is fine for a home user (Steel) if you going to weld alloy or AL that a whole different kettle of fish and more specilist. you be
better with the right gas eg bought argoshield.
Scot's do it better in Kilts.
Viper
| posted on 30/8/04 at 12:56 PM |
If you are welding alli or stainless you wouldn't use an argon co2 mix.
DIY argoshield?? most argon, co2 mixes have other gasses in there as well such as Nitrous oxide, if you were to get yourself a bottle of
argoshield,couger,weldap whatever you wouldn't go back to co2.
liam.mccaffrey
| posted on 30/8/04 at 12:59 PM |
is argo shield that much better?
if it is i'll go straight for that
Build Blog
Build Photo Album
| posted on 30/8/04 at 02:50 PM |
I use the energas product and have used co2 neat. The mix is infinitely better than co2 on locost stuff up to 5mm, less spatter and neater welds.
| posted on 30/8/04 at 03:15 PM |
It's just one of those things that make welding a bit easier... alongside with auto-darkening visors. A good welder can make excellent welds
with CO2, but for us mere mortals the argon mix just makes life less complicated. The arc is a little less 'angry', there's almost
no spatter if the settings are correct, and the end result should be neat and tidy.
In other words - you can manage without it, but you'll find it so much nicer to use.
rgds,
GasGasGas
| posted on 1/9/04 at 07:38 PM |
I have just converted from brewers bottle co2 and got a BOC Argoshield light bottle. I was stupified at the instant improvement in weld quality at the
same settings as my old bottle. Migging with CO2 is an aquired skill, and while it gives a better penetration to your welds its a bugger to get right
and looking proper.
Bite the bullet and get a proper mixed bottle of gas and you wont look back !
While your at get yourself a pair of TIG gauntlets they're far more comfortable to use than the big thickies, the only thing is you have to wait
a bit longer before handling the workpiece after you,ve welded it -- not so much insulation !!!!
[Edited on 1/9/04 by GasGasGas]
wilkingj
| posted on 1/9/04 at 08:49 PM |
You get the better penetration as Argoshield runs the pool hotter, CO2 is a Cold gas, and cools the weld pool.
I always used Argoshield lite its 5% Co2.
I have gone from Argoshield to a Wilco CO2 bottle, as BOC are expensive. No other reasoon, and yes I found it not quite so easy, I am right on the
lowest speed setting with the highest current setting to get a decent weld. Thats with 0.8mm wire.
I think I may go back to 0.6 wire as it gave me a bit more control ie I wasnt on the end of the settings range.
However I was welding 3mm chassis plates, and 5mm to 4mm brackets for my 40ft Aerial Mast. I dont want that falling down!..
Best Regards
Geoff
Best Regards
Geoff
http://www.v8viento.co.uk
Viper
| posted on 1/9/04 at 11:24 PM |
Argon/co2 mix does not give better penetration, it gives a different shape penetration, co2 gives a deeper but narrow penetration whereas mix gives a
wider shallower penetration.
NS Dev
| posted on 5/9/04 at 11:24 AM |
No idea on exact penetration. but CO2 is a better heat conductor and has a higher specific heat capacity than Argon, so CO2 welds cooler and less
prone to burn-through on very thin metals.
If the thinnest I ever had to weld was 1.6mm then I would be using Argoshield (I do for big projects) but much of my work is welding on monocoque
bodyshells at and below 1mm thickness (welding in roll cage feet etc.) and here the CO2 gives welcome cooling to the weld area.
Argoshield is much smoother to use and gives much less splatter though.
Horses for courses but if you rarely have to weld 1mm sheet or less then go for argoshield or equiv.
