posted on 24/4/12 at 09:02 PM |
brake hose clamps - which type?
Need to replace some metal brake pipes and clamp the hoses whilst doing so. Which type of hose clamps to people recommend...?
Been looking at this type...2 x Draper Hydraulic Brake Hose Clamp Pipe Clamping 11534 | eBay
posted on 24/4/12 at 09:19 PM |
I have single one of those I no longer use it it is pretty useless they tend to fly off the hose if they get the slightest knock.
The least damaging type to the hose is the Girling pattern see ebay Item number: 160460380454 but they are a bit bullky most of the time I
use a couple of SnapOn hose nips similar in design to these. ebay Item number: 260956886475
Variations of both are now available under different brand names.
NigeEss
posted on 25/4/12 at 06:36 AM |
Open a bleed nipple, depress brake pedal and wedge it in the down position.
No clamps needed.
SeaBass
posted on 25/4/12 at 08:32 AM |
Bit of rag well folded and a pair of long nose mole grips adjusted so they don't apply too much force.
posted on 25/4/12 at 10:32 AM |
life being what itis is those are always exactly the same molegrips you always want to put the springs & retaining springs on brake shoes and
pads.
[Edited on 25/4/12 by britishtrident]
posted on 25/4/12 at 10:36 AM |
No clamps needed.
The other trick is take the fluid reservoir cap off, top it up right to the very top and put thin polythene over the open top and make an
airtight seal with an elastic band.
