| posted on 24/5/12 at 02:46 PM |
Filling Small Hole in CF...
I had to drill a couple of 5mm dia holes in a carbon-fibre tub to locate an ali insert (stopped at the ali surface).
I won't be using the holes, so want to seal them up. I've filled them with superglue (see pic), but was wondering if I should have used
something else???
It's Evolution Baby!
HowardB
| posted on 24/5/12 at 03:02 PM |
too late, it's a scrapper, you'll have to sell it cheap to some un-suspecting locoter!!
Honestly, the best adhesive would be a good epoxy. Branded epoxies are better. Super glue is very poor at keeping water out, and as you are in
Scotland that might be a concern.
hth
Howard
| posted on 24/5/12 at 03:15 PM |
Cheers. I'll clean it out and replace with some epoxy goo!
twybrow
| posted on 24/5/12 at 04:03 PM |
YOu might want to fill the epoxy a little, to make it less brittle. You could try sanding the backs of the parts lightly, and mixing the dust with the
epoxy to stiffen it up, and to blen in colour wise. It wont be perfect, but better than superglue!
| posted on 24/5/12 at 06:08 PM |
Thanks for that!
