Author: Subject: Torque spanner/extenders - anyone know where I could buy some?
alistairolsen
posted on 23/6/12 at 07:29 PM Reply With Quote
I'm looking for a set of these (or a single one in 13mm if not)
Does anyone know where might sell them? Best I've been able to find are short crows foot spanners?
If not I can always buy some cheap spanners and weld nuts to them but thats a bit shonky!
My Build Thread
v8kid
posted on 23/6/12 at 07:57 PM Reply With Quote
Dunno but I'm intrigued how much do they multiply the torque by?
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
Slimy38
posted on 23/6/12 at 08:18 PM Reply With Quote
They're not really designed to increase torque, they're designed to torque up nuts where a standard socket won't fit due to the thread its going on to. You're even meant to use them at right angles to the torque wrench so the torque setting is still accurate.
I remember looking for one to tighten up a front suspension nut, having to counterhold the damper piston with an allen key meant that you couldn't just use a socket. I thought Cromwell sold them, but I've just had a quick look and can't see them.
wylliezx9r
posted on 23/6/12 at 08:26 PM Reply With Quote
Im pretty sure snapon on do them.
George Best
owelly
posted on 23/6/12 at 08:38 PM Reply With Quote
What size?
http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=631799&group_ID=674855&store=&dir=catalog
http://www.ppcmag.co.uk
Slimy38
posted on 23/6/12 at 08:40 PM Reply With Quote
Yup, it would appear so...
http://buy1.snapon.com/catalog/tools.asp?tool=all&Group_ID=674854&store=snapon-store
And now I know the proper name for them;
Stahlwille Metric 13mm Torque Adaptor. | eBay
Untitled Document
[Edited on 23/6/12 by Slimy38]
owelly
posted on 23/6/12 at 08:45 PM Reply With Quote
http://item.mobileweb.ebay.co.uk/viewitem?itemId=140766907364
alistairolsen
posted on 24/6/12 at 07:41 AM Reply With Quote
Cheers guys. There seems to be some ambiguity over the names they are given and whether folk have heard of them or not!
I need to torque up the cylinder bolts on my bike and they came undone with a ring spanner....
Sadly there's nothing locost about that lot! I suspect Im back to a cheap spanner and break out the welder
My Build Thread
designer
posted on 24/6/12 at 08:08 AM Reply With Quote
Using them will corrupt the torque reading.
Slimy38
posted on 24/6/12 at 08:56 AM Reply With Quote
I was taught that if you keep them at right angles to the torque wrench, the torque at which the head 'clicks' will stay the same as you're not increasing the length of the lever.
Alternatively, you can keep it inline with the torque wrench and calculate how much lower you need to go on the scale based on the increased length.
hughpinder
posted on 28/6/12 at 04:12 PM Reply With Quote
Is there enough room to drop on a box spanner (like a tube with a hexagonal of different size on each end), and then fit a normal socket on the other hexagonal at the free end?
Hugh
