TimC
posted on 2/7/12 at 07:17 PM |
Adding a leading chamfer to a gear; who?
I'm not sure what section to put this in but...
Does anyone have a contact that can add a chamfer to a gear for less than about £30?
Thanks,
Tim
designer
posted on 2/7/12 at 11:32 PM |
Do it yourself on a belt sander.
MakeEverything
posted on 3/7/12 at 06:58 AM |
Or make a jig and put a sanding disc on your grinder.
Kindest Regards,
Richard.
FuryRebuild
posted on 3/7/12 at 08:57 AM |
wouldn't you need to put it back through some kind of surface treatment afterwards?
Mark
www.furyrebuild.co.uk
flak monkey
posted on 3/7/12 at 08:28 PM |
Depending on what you want to do, then I can do that for you....
Assuming you dont want it case hardened again afterwards. Depends on the use of it.
