Author: Subject: Circular hole swaging in aluminum sheet
ceebmoj
posted on 3/7/12 at 10:46 AM Reply With Quote
I need to swage some holes in a peace of 1.5mm aluminum so I was going to make my self a tool like the one below. But for a 50mm hole.
25mmHOLE FLARING TOOL HILLCLIMB FABRICATION SWAGER PREP | eBay
As some of you make fantastic stuff in aluminum my question is. Is there a set angle or radius I should be using on the swagger? I was planning on using a swage of 45 degrees 5mm does that sound about right?
[Edited on 3/7/12 by ceebmoj]
Steve Hignett
posted on 3/7/12 at 10:51 AM Reply With Quote
The angles on this one looks about right...
50MM HOLE SWAGER FLARING TOOL, DRIFT RACE TUNING | eBay
JeffHs
posted on 3/7/12 at 10:59 AM Reply With Quote
For a few holes, you could use MDF as the die and a ball pein hammer to make the flare. I did that successfylly with 20 gaug steel
ceebmoj
posted on 3/7/12 at 11:07 AM Reply With Quote
I have ave ordered the bits of alloy bar to make the swagger. This is a basic project for geting me in to using the lathe.
30 degrees and around 10mm looks about right?
loggyboy
posted on 3/7/12 at 11:59 AM Reply With Quote
I'd say angle is down to preference, but somehwere betterm 20 and 45 degrees would be abot right.
I would say distance would be about 10-15% of the diameter of the hole, so a 20mm hole would have a 2-3mm swage, a 50mm hole would have 5mm.
Mistral Motorsport
imp paul
posted on 3/7/12 at 12:56 PM Reply With Quote
so will you be making a locost type for lads on here ? oops and girlys at a good deal ?
Confused but excited.
posted on 3/7/12 at 01:08 PM Reply With Quote
Surely steel would be a better and cheaper material?
Can't get my head around ali for a swaging tool, seems a bit like a chocolate anvil.
Chippy
posted on 3/7/12 at 01:29 PM Reply With Quote
I have a couple of small ones, 3/4" and 1/2", and they are made with a radiused, (sp), edge rather than an angled edge and make a very neat finish. HTH Ray
Edit to add they are made of steel, not ally
[Edited on 3-7-12 by Chippy]
ceebmoj
posted on 3/7/12 at 02:22 PM Reply With Quote
Just going to be making the one for me for my project.
Given my skills putting a radius on two bits that fit together is probably beyond me so I suspect that a simple angle is what I will do and I may well end up buying one after generating a lot of swarf. As others have pointed out a bit of steel would have been better but I could not find any locally at a sensible price.
ceebmoj
posted on 8/7/12 at 09:09 PM Reply With Quote
Just finished the swager. I used 45 degrees and 5mm then ran over all the corners with some 600 grit. Im very happy with the results in the sheet.
