Author: Subject: How to remove something which is press fit! NOW WITH PICS
Chaz
posted on 3/7/12 at 09:37 PM Reply With Quote
Yes, frustration to a noob looking to remove a drive coupling which has been press fit onto a shaft. Can anyone help? I have looked up some stuff. Some say force, heat and cooling. But I don't know which is safer as I don't want to break the coupling with too much force!
Thanks in advance
Ok see the pics below. I basically want to keep the drive coupling and dont need the shaft. Any ideas?
Charlie
[Edited on 5-7-12 by Chaz]
mookaloid
posted on 3/7/12 at 09:42 PM Reply With Quote
any chance of a picture? Hard to say from that sparse description
madteg
posted on 3/7/12 at 10:01 PM Reply With Quote
Yes need pictures, you could Grind through sleeve till it splits or heat up cherry red and knock off, Press off. As we said need pictures to decide.
Chaz
posted on 3/7/12 at 10:11 PM Reply With Quote
Ok I'll get some pictures, thanks back soon
coyoteboy
posted on 3/7/12 at 10:16 PM Reply With Quote
Again, pictures but:
Similar metals and non temp sensitive parts - you need to heat the lot up as hot as you can physically manage, then cool the shaft while holding it in a vice and try lumping the hot sleeve off.
Dissimilar metals - might just fall off with heat due to different expansion rates.
Caution - quenching steels after heating them a lot can make them brittle and do other damage to heat treating if present. Heating aluminium can trash it by removing factory heat treatment. Heat method is only for last resorts or really over-engineered steel bits.
Otherwise you're going to need to press/pull it off. It may never have been intended to come off again - some cryo-fitted parts literally contact weld themselves together they can be that tight.
stevegough
posted on 4/7/12 at 06:52 AM Reply With Quote
When I have had to replace worn out wheel bearings on my old Audi which were a press fit into the hub, I took the hubs into a local garage who pressed the old one out and the new one in using a hydraulic press. I think they charged me three quid for the first pair, then a tenner for another two a few years later.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Slimy38
posted on 4/7/12 at 08:11 AM Reply With Quote
I have found that most parts which are press fit are not expected to come apart and stay intact. For example press fit bearings generally get destroyed when they're removed.
It might be that you have no choice but to sacrifice the coupling.
coyoteboy
posted on 6/7/12 at 03:51 PM Reply With Quote
That'll press off and right back on again. You might struggle with the old vice techinque but a local garage will have a 10T press that will do the trick.
fullpint
posted on 6/7/12 at 03:57 PM Reply With Quote
You are more than welcome to use my press if you happen to be in the Melksham area... Offer is open to any forum member.
I've over 28 years in dealing with magnesium wheels. Refurbishment and can powder coat most metal parts. Visit my web site if you wish..
www.tpcs-magnesium-refurbs.co.uk
Chaz
posted on 6/7/12 at 04:05 PM Reply With Quote
Can I do this with a vice at home rather than take it to a garage? If so shall I cool it or heat it, how shall I do it?
Thanks again for all your advice here, very much appreciated!
loggyboy
posted on 6/7/12 at 04:06 PM Reply With Quote
will a 2 leg puller not work on that? in vice with the occasion tap from a hammer to shock it out?
Mistral Motorsport
Chaz
posted on 6/7/12 at 04:21 PM Reply With Quote
My two leg puller is quite big for it. Do you suggest I heat or cool it as well?
fullpint
posted on 6/7/12 at 04:36 PM Reply With Quote
Down side of using a hammer to shock it is could end up breaking it where using a pess will force it off. Just depends upon the material.
HowardB
posted on 6/7/12 at 05:18 PM Reply With Quote
here is another option, rather than faff with that lot, sketch what you need, and somone on here might be able to make you a new coupling, so removing all issues and doubts about damage during removal.
Just a wild thought
Howard
Chaz
posted on 6/7/12 at 08:58 PM Reply With Quote
Wow, just used a twin arm pulley puller and it came off! Thanks guys
