Author: Subject: Fitting caliper dust seals
Chippy
posted on 20/8/12 at 10:01 PM Reply With Quote
Sent these pictures to my son, who was helping a friend rebuild a couple of brake calipers, and couldn't get the dust seals to locate. Thought that it may be of use to some people on the forum.
1st picture shows the rusty old caliper that I used for an example, (yours would be nice and clean).
[img] Old caliper
Old caliper
[/img]
2nd shows these cleaned up.
[img] Cleaned areas
Cleaned areas
[/img]
3rd shows the seal, which is slid down from the top so it overlaps the bottom of the piston, helps to smear the piston with some red brake grease.
[img] Seal on
Seal on
[/img]
4th shows the piston held up so the seal will locate into the groove.
[img] Seal in place
Seal in place
[/img]
5th shows the piston pushed down into the caliper, the seal will automaticaly pop into the top groove on its own. Job done.
[img] Piston pushed in
Piston pushed in
[/img]
[Edited on 20-8-12 by Chippy]
posted on 20/8/12 at 11:05 PM Reply With Quote
I didn't know the Titanic had disc brakes
Chippy
posted on 21/8/12 at 01:12 PM Reply With Quote
Hmmm! definately look like its been on the sea bed for a fair time. Cheers Ray
