Bluemoon
posted on 10/9/12 at 12:07 PM |
Cambelt tension gauge?
Hi all,
After reading this tread here.
is it worth getting cambelt tension gauge such as:
this one
For checking/setting up cam-belt tension to date, I have used the twist it and see method; maybe it's time to invest in a gauge?
Dan
snapper
posted on 10/9/12 at 12:38 PM |
Twist it method is fine
I eat to survive
I drink to forget
Fatgadget
posted on 10/9/12 at 12:45 PM |
I ran a 2 litre BDA for years and always used the lookey-feely method of adjusting and tensioning the cam belt!
..The usual disclaimers apply should the above advice prove disastrous for your engine!
[Edited on 10/9/12 by Fatgadget]
Slimy38
posted on 10/9/12 at 12:54 PM |
From memory, the last cam belt change I did was at the direction of the Haynes manual, and they described the 'twist it' method. I
don't remember anywhere talking about the Nm value so the tool would be useless for me.
perksy
posted on 10/9/12 at 04:11 PM |
Twist method on the longest run of the belt is fine
(If you get it too tight it'll hum)
daviep
posted on 10/9/12 at 04:55 PM |
I don't think you could inadvertently over tension a belt to the point it would fail in 500 miles, I would bet my life that belt tension did not
feature in the cause of that idler failure.
In my opinion belt tension is not particularly critical, I've seen plenty engines with belts at both ends of the spectrum, so tight they almost
twang or so loose it looks like it could fall off the pulley.
Davie
