Author: Subject: Compact welding set up
designer
posted on 16/10/12 at 10:37 AM Reply With Quote
I'm after a compact, portable, set of gas welding gear, anybody had any experience of them.
I know they won't be as economical as larger kit, but I want it for track days as an emergency measure.
FuryRebuild
posted on 16/10/12 at 11:29 AM Reply With Quote
If you have trackside power, then inverter fusion tig is really compact and robust.
www.furyrebuild.co.uk
mark chandler
posted on 16/10/12 at 11:32 AM Reply With Quote
Personally I think you would be better off with a small Honda generator and mig/tig invertor.
Carrying a gas set is not going to be great, if you are at any proper track you get electric in the pits.
Regards Mark
dhutch
posted on 16/10/12 at 02:48 PM Reply With Quote
I expect it would be the rental that would kill it, otherwise the oxy/ace are the same you just have less of them so with a half good torch the welding is the same as a larger set.
Else, Im very happy with my esab inveter mig set.
Daniel
posted on 16/10/12 at 05:01 PM Reply With Quote
A small generator will not power a welder. I have a Kemppi generator friendly welder and the minimum recommended is a 5Kva with 8Kva the preferred output. I have a BOC Portapak oxy-acetylene which is probably more like the original idea. It is handy but nowadays is only used for heating stuck fixings and welding the occasional really thin metal.
coyoteboy
posted on 16/10/12 at 05:32 PM Reply With Quote
I LOVE gas welding, such an art to perfect, but I was under the impression that the required safety certs etc pretty much ruled out DIY use above MAP type gases?
