v8kid
| posted on 17/2/13 at 08:04 AM |
2" BSP die loan/use required
Anyone up here able to cut a 2" BSP thread for me or lend the die?
I need to make up a dummy solid insert for the boat flexible coupling to line up the engine to the prop shaft so I can fit the engine mounts.
Have some 2" pipe and 2" threaded flanges but no way to thread them
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
richardm6994
| posted on 17/2/13 at 09:58 AM |
I was in a similar situation a few years ago....I had a piece of steel pipe that needed 2inch bsp thread on the end but no one I knew had a die!
I ended up going to my local speedy hire and the chap behind the counter took my pipe and threaded the end for me with one of these....
http://www.speedyservices.com/product/17_0300-h/hand-threader-electric-amigo-2/productoverview
Hth
owelly
| posted on 17/2/13 at 12:22 PM |
Over the past few years I posted out quite a few taps, dies, and odd tools and stuff. Most of which never got posted back to me. For that reason, I
won't post my pipe dies out but if you tell me how long you want the pipe (in length, not timescale!) I'll thread you a lump of 2"
steam pipe and stick it in the post.
http://www.ppcmag.co.uk
v8kid
| posted on 17/2/13 at 08:09 PM |
Thanks Owelly you are a lifesaver!
U2U sent
Cheers!
chainsaw
v8kid
| posted on 24/2/13 at 05:19 PM |
Thanks Owelly bits received and spot on
U2U sent
chainsaw
