Author: Subject: New toy - scissor lift
jeffw
posted on 6/5/13 at 12:46 PM Reply With Quote
Went and bought something I've been meaning to get for years. A scissor lift. Need to sort out a set of low ramps and a set of high axle stands plus a drill that will drive it but it seems to work well.
bi22le
posted on 6/5/13 at 12:55 PM Reply With Quote
Why would you want axle stands when you have the lift?
Is that one of the tilting bad boys, looks pretty smart?
Please read my ring story:
slingshot2000
posted on 6/5/13 at 01:08 PM Reply With Quote
Would you be willing to risk your life underneath it ?
jeffw
posted on 6/5/13 at 01:10 PM Reply With Quote
I wouldn't be prepared to risk life and limb either. Plus as you say it tilts.....so you need to keep it stable with something.
[Edited on 6/5/13 by jeffw]
beaver34
posted on 6/5/13 at 01:22 PM Reply With Quote
looks good, what costs are these?
bi22le
posted on 6/5/13 at 01:31 PM Reply With Quote
Yup, good point. I just would of thought you could trust it. The only reason I use axles stands for jacks is because its THAT unstable.
Just thought it looks planted enough with good enough contact on the car to not slip.
scudderfish
posted on 6/5/13 at 01:43 PM Reply With Quote
They have a locking pin once tilted, so as trustworthy as the axle stands. If you've got the pivot point approximately under the centre of gravity then if it did fall the actual load dropped on you would be relatively small as it would be mostly balanced by the other end. You can change the tilt one handed so the forces involved are not great.
jeffw
posted on 6/5/13 at 02:10 PM Reply With Quote
Thick end of £500 delivered.
jeffw
posted on 6/5/13 at 02:12 PM Reply With Quote
Very true, I'm still playing with the balance point. What drill do you use for this?
Mark Allanson
posted on 6/5/13 at 04:51 PM Reply With Quote
I have a sudden desire to dust my welder off, and start fabricating!
bi22le
posted on 6/5/13 at 05:04 PM Reply With Quote
Ill have one if your making, a nice drive straight over one would be nice, thanks.
For £500 you can make yourself a nice little earn too.
jeffw
posted on 6/5/13 at 06:07 PM Reply With Quote
If you did a fixed width one that was kit size you could do it cheaper than what I spent. The pads are pretty substantial and you would need to find a way of making it articulate with the car on it.
hobbsy
posted on 6/5/13 at 08:36 PM Reply With Quote
Was this from CJ Autos (?) or somewhere else?
jeffw
posted on 6/5/13 at 09:15 PM Reply With Quote
someone else off ebay.
posted on 6/5/13 at 09:42 PM Reply With Quote
A bit too flimsy for my liking lifting a light car OK but anything heavier.
blakep82
posted on 6/5/13 at 10:01 PM Reply With Quote
hmm, i wonder about an old pallet truck, either to lift under a wheel, or just under the chassis, maybe not particularly high, but could sort of work? or be modified with some ingenuity to make a reasonable height car lift type thing? can't say i've ever really needed to get under my car yet though really. only time was to put the fuel line in the tunnel
i'd like a cheap, smaller way of doing something like this
[Edited on 6/5/13 by blakep82]
________________________
jeffw
posted on 7/5/13 at 04:57 AM Reply With Quote
I certainly wouldn't use it to lift my Jag but the kit is fine.
posted on 7/5/13 at 06:23 AM Reply With Quote
True Story Alert.
A six wheel version of a lift of that style once caused a major problem at an airport not a million miles from where you live.
A fire appliance was on the lift when an insurance inspector spotted a major crack in one of the lifting arms and condemned the lift immediately leaving the fire appliance up in the air. As an airport cannot operate to it licence conditions unless it has x number of fire appliances of specified class the airport had to cancel flights of heavy aircraft until another airport a few mikes down the coast rented them a fire tender.
[Edited on 7/5/13 by britishtrident]
