AndyW
posted on 15/5/13 at 06:39 PM |
todays drilling challenge
OK so here is the case for opinions.
If I had a 2mm aluminium panel which I needed to drill a hole threw but could not get to the other side, how would you drill a hole so you
didn't get any burs on the other side? Hyperthetical question really, just wanted to see what could be done if that was the situation.
Over to you!!!
jps
posted on 15/5/13 at 06:44 PM |
Over to you!!!
What is the application? I.e. - if you can't get to it why would you need to avoid burrs?
posted on 15/5/13 at 06:45 PM |
You could de-burr the hole from the front by poking something through and pulling it back.
MsD
When you say theres no room at the back....
Is there not enough room to get one of these in?
Mark.
AndyW
posted on 15/5/13 at 07:00 PM |
Over to you!!!
For example, if I wanted to put a hole through a panel, then need to put a grommet in. I don't need to just curious as the grommet would not fit
properly due to burs.
minitici
posted on 15/5/13 at 07:20 PM |
Yes - use the de-burring tool show above.
Also useful for opening out holes in Aluminium sheet.
theprisioner
posted on 15/5/13 at 07:50 PM |
Drill out hole with either a hole saw or for more accuracy a Rotabroach cutter and finish off with a flap wheel like
ebay item181096125461 to remove burrs from both sides at once. Only a few turns are necessary.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
chrism
posted on 15/5/13 at 08:58 PM |
Depending how much space there is behind the hole I would have thought a small round file used at a high angle would take the bur off easily, but will
leave the removed metal behind the panel though.
A little hard work never killed anyone, but why take the risk!
Macbeast
posted on 15/5/13 at 08:59 PM |
But if you can't get to the other side what do you need a grommet for ?
Bluemoon
posted on 15/5/13 at 09:57 PM |
You can get special de-buring bits for the deburing tools to do blind holes..
This is what I used on all the blind holes in the chassis as I did'nt want loose rivet syndrome, (for avex muliti grip rivets, much better than
cheap and nasty garden variety everyone seems to use). Worked well for me, tool needed a quick touch on the Grinding wheel to fit into the 4.2mm rivet
holes...
Dan
[Edited on 16/5/13 by Bluemoon]
