theprisioner
| posted on 25/6/13 at 03:33 PM |
Experianced welders advice
  Racing Puma inlet manifold
The above is part of a Racing Puma inlet manifold. It is broken, resulting in my iva fail. These manifolds are scarcer than hens teeth. Any advice on
the best way to weld it would be appreciated?
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
mark chandler
| posted on 25/6/13 at 03:59 PM |
Deep v and TIG weld would sort it.
Should cost peanuts
minitici
| posted on 25/6/13 at 04:23 PM |
Want to bring it across to Dunfermline and I can try Tigging it.
Douglas.
| posted on 25/6/13 at 07:00 PM |
It's aluminium isn't it ? It should tig with 4043 rod simply enough, nothing fancy about it.
[Edited on 26/6/13 by Peteff]
Talon Motorsport
| posted on 25/6/13 at 09:48 PM |
Just to point out that this will be cheap grainy bastardised cast ali not pure solid ali, when you hit it with the TIG arc the crap in it will blow
out the same as trying to weld galv.
snakebelly
| posted on 25/6/13 at 10:11 PM |
Yep looking at the granular nature of the casting i have to agree. I think that will be a bit more difficult than it looks at first glance. You may
have more luck using some durafix rods or similar rather than tig. Good luck either way hope you get it fixed
PhillipM
| posted on 25/6/13 at 10:57 PM |
It might be an idea to just hit it with the torch and boil the impurities out first, then grind it clean and fill the gap with rod. It does mean
you'll need to make a jig though as obviously misalignment could be an issue.
ragindave
| posted on 26/6/13 at 06:20 AM |
Super glue!
theprisioner
| posted on 26/6/13 at 10:38 AM |
Decision (and thanks to all who contributed to this thread)
I have not done enough cast alloy welding to entrust myself with a part costing me £700 s/h (purchased over a year ago and fitted by the engine
tuners). However the last time I welded a casting of that sort I used a spool on Mig and grew a new part of the casting as the bit causing the hole
was missing. It was however totally successful but was owned by someone else!!!
Plan A
I have entrusted it to a friend who has more experience than me with alloy cast welding, he is currently cleaning the casting in an ultrasonic bath
most of today. He is then going to jig the part tack the break it at either end then V cut the crack on both sides. The hole job will be heated very
hot before any welding.
I am not even going to look at what he is doing while he is doing it. When finished he is going to rough grind it when finished and leave the final
finish to myself. I can face it up on the milling machine when finished as necessary.
Plan B
Grow a new lug as above if plan A fails!
ashg
| posted on 26/6/13 at 11:42 AM |
it will tig up. i have done loads of cast ali and its much easier to do than cast iron
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
