Slimy38
| posted on 18/8/13 at 11:48 AM |
alternatives to lifting chain
Just a quick question really, I want to do the locost thing when it comes to lifting the MX5 chassis up. I'm happy with the choice of engine
crane, but I haven't got any chain. I do have;
1. Ratchet tie down strap with nylon webbing.
2. Climbing rope.
Both are rated to a few thousand kg's breaking strength, and both are long enough to double up as well. I'm slightly edging towards the
tie down strap mainly because the climbing rope is dynamic. Anyone got any thoughts?
designer
| posted on 18/8/13 at 11:53 AM |
Straps are ideal, a lot easier to handle than chain.
balidey
| posted on 18/8/13 at 12:29 PM |
I usually using webbing straps as I usually have a few lying around, they are easily adjusted to length, you can double them up, kinder to soft metal
parts and most important, IF they break, its a usually a more gentle failure, giving you time to move toes. Chain tends to go with a bang
Dutch bears have terrible skin due to their clogged paws
Mikef
| posted on 18/8/13 at 12:36 PM |
I would go with the slings, I have a couple I use and are a lot easier than chain, just make sure the rating is ok, and that they dont slip.
MF
gremlin1234
| posted on 18/8/13 at 12:41 PM |
use the old seat belts from the donor car as straps?
| posted on 18/8/13 at 12:44 PM |
Thats what I used, no trouble picking up my V8 with gearbox and trans case.
scudderfish
| posted on 18/8/13 at 01:04 PM |
I bought a load leveller when I was doing my V8 swap, and it was my favourite tool. Being able to minutely change the angle of the dangle as I
negotiated the engine and gearbox through the chassis made it worth it's weight in gold.
http://www.amazon.co.uk/750kg-Leveller-Engine-Crane-Cranes/dp/B004DDV27U/ref=sr_1_2?ie=UTF8&qid=1376831020&sr=8-2&keywords=load+leveller
Slimy38
| posted on 18/8/13 at 01:44 PM |
They're going to be donated to the new car!
Looks like the straps have the vote, thanks all.
