Author: Subject: How to cut a thread with a die
Slimy38
posted on 20/8/13 at 05:32 PM Reply With Quote
I'm looking for M18 x 1.5 threaded rod, and as always it's 'challenging' to find. The only supplier I found on this side of the pond is out of stock.
So, time to consider cutting a thread. I did it once in school and remember the technique, but I'm no engineer and was just copying rather than learning. If I'm looking at an M18 thread, do I start with 18mm steel?
dave_424
posted on 20/8/13 at 05:44 PM Reply With Quote
Yes, 18mm OD steel rod for M18 thread.
How long do you need the threaded pieces?
Dave
Slimy38
posted on 20/8/13 at 05:59 PM Reply With Quote
The inserts are 60mm long and I'm guessing the more the thread the better, so maybe 70-80mm times four? I had thought of finding suitable set screws and cutting the head off, but even that seems harder than expected.
CNHSS1
posted on 20/8/13 at 06:26 PM Reply With Quote
Try Non Standard Socket Screw Company in Brum, they probably have them off the shelf
mark chandler
posted on 20/8/13 at 06:30 PM Reply With Quote
I got a couple 3/4 UNF bolts off eBay the other day, these are pretty much the equivalent if you are making up something, I wanted them to make a puller
http://www.ebay.co.uk/itm/261206411703?var=560195347030&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Slimy38
posted on 20/8/13 at 06:43 PM Reply With Quote
They're going to be the suspension adjusters for the rear suspension. I'm guessing your plan of using them for a puller suggests that they would be able to sustain a decent amount of pulling forces?
mark chandler
posted on 20/8/13 at 06:57 PM Reply With Quote
My rear suspension sits on 1/2" unf rose joints, 3/4" is more your commercial size, landrovers etc.
McGills sells threaded bungs to suit.
Regards Mark
liam.mccaffrey
posted on 20/8/13 at 07:19 PM Reply With Quote
my machinist could make those up for you very reasonably if you can't find off the shelf. I'm going to see him tomorrow I could get a price if you want
Build Blog
Build Photo Album
Simon
posted on 20/8/13 at 07:46 PM Reply With Quote
http://www.mbefasteners.co.uk/
Simon
Slimy38
posted on 20/8/13 at 08:11 PM Reply With Quote
Simon
Query posted, thanks!
Slimy38
posted on 20/8/13 at 08:21 PM Reply With Quote
That would be great if you could? Could you possibly get a price for the inserts as well, £10 a pair is about as cheap as I can get them at the moment?
I'm after;
6 x M18 x 1.5 (fine thread) x 60mm inserts. The Ebay ones are made out of 30mm metal.
4 x M18 x 1.5 (fine thread) x 80mm threaded rod.
Slimy38
posted on 20/8/13 at 08:26 PM Reply With Quote
Regards Mark
I believe the basis for the M18 insert is the Transit ball joint, so yes definitely commercial size. I don't really need to use M18 inserts for the rear, but having found the inserts it makes sense to stick with what's available.
