joneh
posted on 22/10/13 at 08:30 AM |
Hobby weld 5
Hi collective wisdom,
How long would you expect a cylinder of hobby weld 5 last?
I use it around 15lpm and it's only done about 2kg of wire...
Capacity - 1.34m3
Water Capacity - 9 Litres of gas per cylinder
Jon
40inches
posted on 22/10/13 at 08:47 AM |
Play around with the gas flow, I have got mine down to 5-6lpm indoors and works fine, however if you are working outside 15 may be needed.
mike2704
posted on 22/10/13 at 08:52 AM |
hobby gas
Hi, Hobby gas bottles are never full they must leak or something because the never last long you'd be better off getting a larger bottle from
gas supplier.
I can't remember how many times I've complained mainly to Halfords to no avail.
Hope this helps. Mike
iank
posted on 22/10/13 at 09:01 AM |
Hobby welders often come with cheap valves (both in the gun and on the cylinder) which leak slightly even if closed meaning you can lose a fair amount
of gas even when you're not using it.
Better to get a small bottle from a supplier and a decent gauge.
Anonymous
robocog
posted on 22/10/13 at 09:05 AM |
could possibly turn the flow down to 10lpm to try and get longer weld times
You may be able to go lower than that without causing issues if indoors
The answer to your question is missing gas bottle pressure to calculate the total weld time I think
pressure x litres = total litres
to get total welding time is
total litres / flow rate
I could be wrong though :-)
Regards
Rob
Minicooper
posted on 22/10/13 at 09:33 AM |
A quick search round the web comes up with
At 10lpm:
Hobbyweld 9.5l @ 137 bar => 2 hours 10 minutes.
Since your using 15lpm your weld time will be a lot less
I usually set mine about 8lpm (indoors)
ashg
posted on 22/10/13 at 10:37 AM |
i run about 7-8 up to about 11-12 outside. if its really windy i wait for a nicer day
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
joneh
posted on 22/10/13 at 10:59 AM |
Cheers guys, running at a lower lpm works fine. I'll keep switching off between welds.
Jon
DIY Si
posted on 22/10/13 at 11:24 AM |
The other thing I found with the hobby bottles was that unscrewing the valve from the bottle when it's not in use made a huge difference to how
long a bottle would last. I've had some go flat over the course of a week of being connected but not used before, which is a massive PITA.
Sun Tzu, The Art of War
Depends how much welding you have to do of course, but a proper bottle with valve and gauge is the way to go. Think I paid my local welding supplies
place £50 lifetime rental + £30-40 for the Argoshield gas + £about £35 for a valve/gauge. Connects directly to the little white hose on the welder
and has the security of a decent shut off valve so you don't lose gas when not welding.
corrado vr6
posted on 22/10/13 at 03:18 PM |
Have a read through this
http://www.theminiforum.co.uk/forums/topic/264295-help-needed-with-a-dispute-with-hobbyweld/?fromsearch=1
There has been another simular topic recently on the same forum
http://r1indy7.wordpress.com/
