nick-york
| posted on 25/10/13 at 09:41 AM |
Bodge job !
Well I've tried to drill and tap some holes in my aluminium petrol tank to mount my sender unit . And I've bodged it up !! I've
never attempted tapping holes before and thought it would be easy !The holes were too large a diameter for the tap so couldn't get enough
thread. I think the holes were not drilled precise enough because the drill must of slipped and made the holes not 100% round ! Bit of a disaster
really ! Can anybody recommend somebody in or very near to York who could fit the sender for me ? Once that's done the tank can be fitted . Im
not after a freebie . Don't mind paying.im sure its not going to cost a fortune ! Cheers !
[Edited on 25/10/13 by nick-york] hi ! The aluminium is a 10 mm thick ring welded on the tank specially for the sender unit.I think the drill size was
5 mm for a 5.5 mm bolt ! I did start to drill one of the holes out to use a larger bolt but stopped because i didn't want to mess up again. I
don't think rivnuts would work this time.but they do have their uses . I might have to look in the good old yellow pages and ring round some
local engineers. But recommended people always come first if anybody knows anybody. Cheers.
Neb
| posted on 25/10/13 at 09:54 AM |
Could you put a series of rivnuts in it with a dab of sealer?
[Edited on 25/10/13 by Neb]
carpmart
| posted on 25/10/13 at 09:56 AM |
Tap them out bigger and use larger fixings?
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
will121
| posted on 25/10/13 at 10:00 AM |
What size drill did you use for the size of tap? For drill size it normal to take thread pitch away from the drill size, eg 6x1mm bolt drill a 5mm
hole but as you say needs to be a round hole not shape of an egg, a step drill in thin metal can give a better shaped hole than a cheap drill bit
MakeEverything
| posted on 25/10/13 at 10:07 AM |
http://www.kasthurimmc.com/tap-drill-chart.html
Kindest Regards,
Richard.
designer
| posted on 25/10/13 at 10:13 AM |
How thick is the aluminium? Could be too thin to tap.
[Edited on 25-10-13 by designer]
Smoking Frog
| posted on 25/10/13 at 10:14 AM |
Sorry can't recommend somebody in York. But could get round it by making a "C" ring that fits inside the tank. I don't think
the tank would have enough thickness to take a decent thread anyway.
stevebubs
| posted on 25/10/13 at 11:13 AM |
Seconded on the rivnuts / internal ring - my tank is certainly too thin to tap successfully....
If going down the rivnut route, need a suitable thick gasket to seal around the rivnut flanges...
big-vee-twin
| posted on 25/10/13 at 11:18 AM |
Mine is fitted with rivnuts.
You can uses rivnut with a 5mm thread hole would be bigger around 8mm.
Have you got a rivnut tool.
http://www.triangleltd.com
Tinks1
| posted on 25/10/13 at 12:14 PM |
I the material is 10mm thick you could always helicoil
big_wasa
| posted on 25/10/13 at 12:28 PM |
gets my vote.
fazerruss
| posted on 25/10/13 at 12:59 PM |
If you are stuck I could sort it for you. I've got taps,dies, mig, tig, milling machine, lathe ect
Russ
"if assholes could fly this place would be an airport"
renetom
| posted on 25/10/13 at 04:55 PM |
If the material is 10mm thick, just turn it around a bit & drill & tap
a new set of holes , does not matter about the old holes as
the gasket will take care of it.
Simplest solutions are always best.
good luck
40inches
| posted on 25/10/13 at 06:35 PM |
good luck
You beat me to it
Drill and tap one hole, fit the sender using the one hole.
Using a drill the same size as the mounting hole in the sender,drill opposite the drilled and tapped hole, using the sender mounting plate as a jig,
only drill enough to make a drill guide, sort of like a large centre pop.
Remove sender and drill and tap second hole, refit sender with two screws, repeat with all the other mounting holes.
Using the sender mounting plate as a jig will ensure all the holes line up.
Use lots of lube on the drill and tap, and with ally turn the tap in only one full turn at a time, backing off 1/2 turn.
nick-york
| posted on 26/10/13 at 06:30 PM |
sorry for been thick but I've never heard of helicoil before ! What is it please
ReMan
| posted on 26/10/13 at 06:38 PM |
Not thick at all.
But you've obviously not owned any old british bikes!
http://www.helicoil.com.sg/HeliCoil-Installation-Instructions.shtml
www.plusnine.co.uk
Wheels244
| posted on 26/10/13 at 07:22 PM |
Nick
You can take it to my brothers engineering business on James Street if you like.
http://www.lowtonengineering.co.uk/
It won't be that expensive to do.
Let me know if you're going to take it and I'll try to get you mates rates.
Rob
nick-york
| posted on 26/10/13 at 08:01 PM |
quote: Originally posted by Wheels244
Nick
Rob
Hi Rob ! That's fantastic ! I can take it on Monday morning .cheers mate.
nick-york
| posted on 26/10/13 at 08:16 PM |
Well they say you learn something new everyday ! I thought everybody bolted their sender units to their tanks in tapped holes .I didn't think
there was an alternative .but it seems some of you use rivets or helicoil !I am always amazed at the amount of help and ideas i get from everybody
when im a bit stuck . Just hope i haven't overlooked any of the help . So much to look through! Thanks for all the help everybody!
Wheels244
| posted on 26/10/13 at 08:26 PM |
Happy to help Nick.
I'll ring him and tell him to expect you - his workshop is on the Raylor Centre.
I'm in York fairly often (home town) if I can help with anything just let me know.
Rob
nick-york
| posted on 26/10/13 at 08:34 PM |
Happy to help Nick.
Rob
excellent ! Much appreciated Rob ! My brother has his office on the Raylor Centre as well .
Wheels244
| posted on 27/10/13 at 07:05 PM |
He's expecting you Nick.
My brother's name is Chris, his partner (business !) is Phil.
He'll sort it for you.
Rob
nick-york
| posted on 27/10/13 at 09:04 PM |
Excellent ! Thanks a lot for that !
nick-york
| posted on 29/10/13 at 08:13 AM |
Rob
Tank dropped off yesterday morning as arranged and will be ready on Friday. Chris was very helpful. Because my original holes
weren't lined up very accurately it would of been hard to helicoil them. So Chris recommended rotating the sender unit slightly and drilling and
tapping some new holes .
Wheels244
| posted on 29/10/13 at 11:26 PM |
Glad you got sorted Nick.
Sorry forgot to tell you about Zara, the German Shepherd - ain't no one burgling my brother !
