coyoteboy
| posted on 31/10/13 at 02:16 AM |
Odd stainless fasteners fyi
http://www.stainlessautomotivefastenings.co.uk/
Ntdwm but just found them when looking for an m8 bolt with an m6 head. Don't ask.
dave r
| posted on 31/10/13 at 06:39 AM |
loads of stuff on there.... any idea who or where they are... the website appear to omit that bit
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
minitici
| posted on 31/10/13 at 08:26 AM |
search deep enough on the site and you find:
Stainless Automotive Fastenings Ltd 4 Holding Heatley Lane Broomhall Nantwich Cheshire United Kingdom CW5 8BA
mcerd1
| posted on 31/10/13 at 09:02 AM |
did you find the bolt you were looking for ?
a lot of the DIN and ISO spec bolts have smaller heads than our BS ones....
coyoteboy
| posted on 31/10/13 at 09:37 AM |
Interestingly I can't seem to put an order through the site - have emailed them directly.
I found the one I want in there (essentially I have an M8 threaded female part and I need it to fit into a hole milled for an M6 head! No-one else
seems to do them which is unfortunate!
mcerd1
| posted on 31/10/13 at 09:56 AM |
^^^ is it a cap head bolt you want like this:
coyoteboy
| posted on 31/10/13 at 10:16 AM |
Yup!
I have a counterbored hole 6mm deep and 11 diam to get an M8 threaded fastener into! (UI can drill out the main shank diam no problem but the
counterbore is a different matter)
[Edited on 31/10/13 by coyoteboy]
mcerd1
| posted on 31/10/13 at 11:17 AM |
you need one of these then
http://www.ebay.co.uk/itm/HSS-M8-8mm-Counterbore-15mm-Cutter-Dia-Plain-Shank-/150030630853?pt=UK_Hand_Tools_Equipment&hash=item22ee85bfc5
(there are cheaper ones btw, thats just the first link I found that size...)
coyoteboy
| posted on 31/10/13 at 12:41 PM |
lol, yep and a milling machine to do it on as it'll breach the edge of the part
mcerd1
| posted on 31/10/13 at 01:19 PM |
ok here's another idea:
what about making up a steel spacer on the lathe, ~11mm outside dia. with 8.5mm through hole and ~6mm think
then pop that in the hole and just use a standard M8 bolt (could be a button head if you need a minimal projection)
