Nice idea. I also used some flexible ducting covered in brown parcel tape and then applied fibreglass. The tape helps to keep the shape and creates
a non stick barrier. The inside is never as good as the video though.
From what I can see from the video, the tape doesn't adhere to whatever it's wrapped around. I think I will buy some and experiment a
little
quote:Originally posted by unijacko67
Is the tape expensive and where have you ordered it from, I need to alter my intake so could be just the job.
eBay link under video in first post. Not at all expensive
Sorry, I missed link, should have gone to spec savers eh. Just trying to come up with an idea as to how to make a quick and easy mould now. Wrapping
flexible pipe with parcel tape could work. Cheers.
1) If you can make the buck from nice metal tube then you have done the job
2) It has holes in it so you will have to use lots of tape to make sure every little hole is covered with another layer
3) sliding or fitting fixings that are a standard size to each end may be a problem as well as getting a good seal.
I do have answers for these thought!!
1) depending on the shape you want to acheive you could use expanding foam \ polystyrene block and shave to shape, cover with parcel tape \ duct
tape. When set rip, poke and push the softer insides out.
2) Create a thin single layer, then wrap the whole thing again using parcel tape \ duct tape to create a air tight membrane, then rewrap a second
layer of casting tape. This will create a strong and air tight cast.
3) Not sure how to solve this!! Ideas??
Photo Archive
Building: Dax Rush - very, very slowly....
posted on 24/1/14 at 03:55 PM
quote:Originally posted by big_wasa
Also available in red but I was amazed at how little mess there was and how quick it cured
hope your heals quicker than mine (19 weeks + for mine )
I only got offered white ones - must be the nhs cutting back... yuck!
if you soak the tape in hot water it cures much, much faster ! (about 1min instead of 10min)
not so hot that you burn your hands mind
I'm told its best to do a few cold ones first and when your getting good/quick at it then you can try a hot one
I was used as an example for training a junior doctor - somehow I never thought I'd be able to use this knowledge on a car...
Photo Archive
posted on 24/1/14 at 04:15 PM
quote:Originally posted by bi22le
My concerns with this method would be:
1) depending on the shape you want to acheive you could use expanding foam polystyrene block and shave to shape, cover with parcel tape duct tape.
2) Create a thin single layer, then wrap the whole thing again using parcel tape duct tape to create a air tight membrane, then rewrap a second layer
1 - in the video they are only making these to replace the metal ones in an effort to reduce weight and thermal conductivity (to reduce heat soak -
the cars in the video's all have big turbo setups, so that means lots of heat under the bonnet)
2 - wrapping with a second layer of any kind of tape is unlikely to be good enough for the sorts of pressures / vacuums.
As per the video it'll need liquid resin and more layers of glass or carbon to make it airtight and strong enough
even once the tape has cured its still got a little flex in it, after my experience of it last year it needs at least a double layer to have any
rigidity and even then its still got asome 'spring' in it - its ideal to use as a former that gets left in situ though
3 - the best way to make it fit standard pipes would be to bond in pre-made metal or plastic ends
Photo Archive
posted on 25/1/14 at 12:28 AM
Thanks I hope so or I am screwed good look with yours...
mines all healed now - well it seems to be anyway...
it was a mid waist fracture of the scaphoid, which is a slow one anyway and mine turned out to be extra slow
(half as long again as all the other folk in the same clinic as me and I don't even smoke!)
I was in plaster for ~12/13 weeks then a splint after that
I even ended up paying for CT scan so I wouldn't have to wait for the NHS to do it - turned out to be a total waste of a scan too as it
didn't show much more than the x-rays
at 19 weeks they told me I could take the splint off part of the time and I could drive again
but it was about 4 weeks after that before the last x-rays and that showed it was about 95% healed
so they said it it'd be fine now and don't come back.... so I've never seen an x-ray without the break in it
just to make it extra difficult I had a broken ankle at the same time, but that was nothing as it was healed in 6 weeks
