matty h
| posted on 29/1/14 at 09:07 PM |
Lathe tool set up
I am wanting to turn a shaft down on a lathe, I have a lathe available to me but used to get someone to do it for me or set it up for me but he has
retired now.
My question is once I have set the tool height what angle do I need to set the tool to the shaft/work.
When I have seen it done it was set at 90 to the work then angled into the work slightly I assume this was done with experience but I do not have this
so is there a specified angle I need to set it out.
Thanks in advance.
Matty
Theshed
| posted on 29/1/14 at 09:37 PM |
It rather depends! It depends on the shape of the tool and the direction you are cutting (i.e. plain turning or facing etc). I assume it is a HSS tool
rather than a tool with a carbide insert?
In the absence of any other info - If plain turning right to left (and assuming a knife tool of some sort) I would have the left hand edge (that does
the cutting) at about 7 degrees anticlockwise.
chris-g
| posted on 29/1/14 at 09:47 PM |
This web site should help.
http://easyweb.easynet.co.uk/~chrish/cancelled%20account/techindx.htm
T66
| posted on 30/1/14 at 12:03 AM |
useful little site ! - we need a sticky thread with links like this in.
chris-g
| posted on 30/1/14 at 08:51 AM |
Yes, its got lots of very good information. I should have posted the link the the main homepage so here it is.
http://easyweb.easynet.co.uk/~chrish/cancelled%20account/homepge2.htm
Chris Heapy, the author must have spent quite some time on it so he deserves a big thank you.
matty h
| posted on 30/1/14 at 07:22 PM |
Done a bit of turning today seems to be going ok but finish is a bit ruff, although I have now found the correct levers to select the auto feed.
Thanks for the advise and links.
Matty
