mookaloid
| posted on 11/5/14 at 07:15 AM |
2 or 4 poster
Just looking at the 'money no object tools' thread.
I am wondering why some people seem to prefer the 4 post lift or the 2 post lift.
I would have thought that the 2 post would have been preferred because it is less 'in the way' and because the wheels are instantly off
the ground.
What am I missing?
Mark
owelly
| posted on 11/5/14 at 07:43 AM |
I'm a fan of four posters as that's what I've used the most. Usually with a set of 'free-wheel bars' and beam jack. They
do take up more room but imho, are safer. I've seen a few incidents where vehicles have toppled off two-posters. If you're doing an engine
change on a two poster, the balance goes out of the window once the engine is removed. Also, swinging on tight hub nuts and levering stuff needs extra
care with a two poster. A four poster with 'free-wheel bars' can do most of what a two poster can do apart from a complete subframe
assembly removal, so you'd use the beam jack. But that would get in the way if you were then removing the exhaust.....
http://www.ppcmag.co.uk
| posted on 11/5/14 at 07:56 AM |
I've been in the motor trade for 47 years now and have used all sorts of lifts . All of them have disadvantages but if I hade to pick one
without any doubt it would be a two poster, properly used I have never seen any problems with cars falling off but there is always some idiots about ,
it has far greater access to the underside with only 2 disadvantages , door opening restricted and not being able to check suspension ball joints
when loaded unless you use some sort of table. Beats any 4 poster for versatility
ian locostzx9rc2
| posted on 11/5/14 at 08:03 AM |
There a few occasions where a four post ramp would be better but for general maintaince 2 posters are much more practical... And usable.
Slimy38
| posted on 11/5/14 at 08:10 AM |
Mmm, this never even occurred to me. I thought even 2 post lifts have 4 points of contact, but then having a look at an Ebay lift I saw this bit of
text;
Operator should use care when working on vehicles that have an abundant amount of undercoating (lift pads may “slide”) or a significant weight
imbalance of the vehicle may occur due to removal of an engine or transmission. Also, “HEAVY wrenching” may result in a vehicle shifting weight on the
arm pads. We recommend the use of tall jack stands under the vehicle to add another layer of safety.
CosKev3
| posted on 11/5/14 at 10:00 AM |
text;
even with 4 contact points its still down to the user to position the vehicle and ramp arms correctly to get the correct balance
Surprising how easy it is with some cars to get the balance wrong.
mark chandler
| posted on 11/5/14 at 10:14 AM |
Two post lift is the one to go for in a small garage, a four post just takes up to much space.
Make sure you get one with nice long feet, ideally these will be longer than the arms when extended so you are not so dependant upon the garage floor.
