blakep82
| posted on 14/5/14 at 04:54 PM |
se16c150 compressor gasket
The gasket on the air delivery pipe on my clarke compressor has gone. A new gasket set is 30 quid, surely I could get some gasket paper and make the
one I need easy enough?
Anyone done this yet? What type and thickness do I need?
________________________
mark chandler
| posted on 14/5/14 at 08:32 PM |
Lot less pressure than a head gasket!
Get a selection of gasket paper off eBay, pick one out the set that looks right, hold over the hole and gently tap around the edges with the round end
of a small ball pien hammer to cut the paper.
Where the bolts go through lay a ball bearing over the hole and tap to punch out the hole.
With care you can make most soft gaskets like this.
And alternative is the get a block, better a piece of glass and some fine wet and dry to get the mating surfaces really flat then smear of hylomar and
lay a silk thread around the hole then tighten it's how rolls Royce used to do things years ago.
Regards Mark
blakep82
| posted on 14/5/14 at 09:06 PM |
Cheers Mark
Are there different types of material? I ordered a peice 0.5mm thick, but said its used on model steam engines. Steam, air, same thing lol
Others were oil and water, so wasnt sure if the pressure was up to it.
Was only 1.95 posted
Other selection packs had different thicknesses, but only mentioned oil and water
I've not been able to take the old one out yet, so I'm not sure on the space I'll be able to make without bending copper air
delivery pipes too far
