NigeEss
| posted on 26/7/14 at 07:53 PM |
160A AC TIG, capability ?
Looking at replacing my ancient mahoosive AC/DC TIG with something more modern.
Was curious as to what thickness aluminium it can weld. My current one has been used to repair
wheels and engine casings, would a 160A (eg R-Tech) manage that ?
dave_424
| posted on 26/7/14 at 08:22 PM |
Yesterday welded 10mm aluminium with 140A, ground a nice bevel on both sides and worked fine, 140A and full pedal was a bit on the hot side.
160A would be able to weld pretty much any thickness, sonething like a 1" tee joint would just take a couple of passes
Volvorsport
| posted on 26/7/14 at 09:37 PM |
interested in selling ?
www.dbsmotorsport.co.uk
getting dirty under a bus
prawnabie
| posted on 27/7/14 at 07:50 AM |
I bought an RTECH 160 ac/dc nearly 2 year ago and have yet to use it : (
snakebelly
| posted on 27/7/14 at 08:16 AM |
I have the R-Tech 160 AC / DC and have yet to find anything it can't do within reason, sometimes it needs multiple passes and yes on thick Ali
it all gets a bit warm but as long you're not in a rush it copes well. I'm sure you've seen my post about the R-Tech discount code
for this month?
froggy
| posted on 27/7/14 at 01:12 PM |
I use a map gas torch on castings with my r tech 160 , still needs pretty much full power to get going but the heat lets you back off a bit once your
flowing
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
NigeEss
| posted on 27/7/14 at 01:29 PM |
Yes, it's old, big and heavy. Sureweld AC/DC 180. Currently set up for 240v single phase but can be switched
to 440v three phase.
[img] [/img]
Volvorsport
| posted on 27/7/14 at 03:28 PM |
Does it have any accessories? Pm me if you have a price in mind
NigeEss
| posted on 27/7/14 at 04:01 PM |
Yes, torch on quite a long lead/pipe, gas pipe and a long earth lead.
Mains cable currently has a poorly fitted 16a plug but could do being on a 32a as
it trips my supply when wound up to the higher settings.
I'll be keeping the gas bottle and regulator.
baz-R
| posted on 27/7/14 at 05:08 PM |
remember in ac around half the current is goning the wrong way to break the oxide film
you want to go as big as you can so 200-250 is where you need to be to have a bit of kit thats useful but to weld wheels and castings you would still
need to pre heat
r1_pete
| posted on 27/7/14 at 06:18 PM |
I've done a lot of 1/4 inch casting to 3.2 mm alloy tube, building manifolds, and 5mm to 5mm casting with the R Tech 160 on 100 - 110 amp no
problem..
When I bought it, I was going to go for the 200, but R Tech said on a domestic supply I wouldn't get any benefit from the extra 40 amps, as at
much over 160 it would exceed the supply current, and pop fuses / breakers.
[Edited on 27/7/14 by r1_pete]
