Author: Subject: Need help BEC
timi7
posted on 17/10/14 at 05:35 PM Reply With Quote
Need help BEC
Need a little help guys and girls
I have a knocking when above 50 mph ish, seems like the propshaft. Looking furthur into it it does seem to be the UJ, how do i know what UJ it is to replace it?
Also, anyone else had the same or similar problem?
kj
posted on 17/10/14 at 05:52 PM Reply With Quote
Have you checked the prop adapter ?
Think about it, think about it again and then do it.
kj
Where in the UK are you
timi7
posted on 17/10/14 at 05:54 PM Reply With Quote
No i haven't, could it be that maybe
West Yorkshire
40inches
posted on 17/10/14 at 05:59 PM Reply With Quote
The UJ's on my prop were GKN Freelander. You will need to measure the overall width, and the diameter of the bearing cups,
expect to pay between £35-£50 a joint, any less than that are likely to be cheap Chinese ones
If you are stuck I have a new GKN joint somewhere in the garage.
timi7
posted on 17/10/14 at 06:01 PM Reply With Quote
Thanks 40 inches, i will let you know if i do
matty h
posted on 17/10/14 at 06:11 PM Reply With Quote
You could take your prop to the proffesionals to check like dunning and fairbanks.
http://www.dandfltd.co.uk/
Matty
timi7
posted on 17/10/14 at 06:18 PM Reply With Quote
Yes i was thinking of going straight to them but thought i would ask first
Thanks Matt
kj
posted on 17/10/14 at 07:15 PM Reply With Quote
My prop developed a vibration about same speed ,it had started to come loose here to be tightened and re greased
timi7
posted on 17/10/14 at 07:34 PM Reply With Quote
Thanks KJ, i'll get it checked
