Author: Subject: Workzone Sand Blaster Review (from Aldi)
micksalt
posted on 4/9/15 at 07:29 AM Reply With Quote
I've had a few of these 'middle aisle' tools, and some have been great. However, when I wore out the wire brush on the angle grinder whilst preparing some metal gates, I thought I'd give this a go. Don't bother wasting your time and money, it basically tickles the old paint. Sometimes you get lucky, but in this case, it was definitely a case of getting what you paid for.
coyoteboy
posted on 4/9/15 at 08:37 AM Reply With Quote
Got an image of it? I got this one a while back
Blaster
Blaster
And it's worked a treat, stripped dozens of rust manifolds and prepped loads of cam covers for painting.
Won't cut through the really bad stuff without hovering for a few seconds but eventually gets through and will eat the base metal. What's the workzone one like? What media did you use?
[Edited on 4/9/15 by coyoteboy]
v8kid
posted on 4/9/15 at 12:12 PM Reply With Quote
cyoteboy where did you get yours? what pressure and flow does it take and what grit do you use
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
coyoteboy
posted on 4/9/15 at 12:24 PM Reply With Quote
Mine was a sealey kit, it runs at 80psi off my DIY compressor which instructions say maxes at 9.5cfm when pumping but if allowed time to charge the cyl I get 2-3 mins blasting then 2-3 mins waiting, below 40psi it's not very good. I built the box from OSB and I've been using al oxide. Also used a 150W lamp in the cabinet and a face mask because it can still get pretty dust outside.
coyoteboy
posted on 4/9/15 at 12:25 PM Reply With Quote
Double post
v8kid
posted on 4/9/15 at 03:00 PM Reply With Quote
excellent thanks
