Rob Lane
| posted on 10/12/04 at 09:01 AM |
Cheap car lift
Well, after waiting for Machine Mart to answer my questions regarding their high lift pallet truck, I have found and purchased a better/cheaper one.
£180 inc VAT.
This is much better built than the MM one and has full lift of 850mm at 1000kg capacity. As the 7 is 550kg it's well within its limits. The
company had kindly loaded a 1000kg pallet to full lift and left it there for me to inspect/check it's capacity.
Only problem is, now I've got to get it out of my van !! It took 4 guys to lift it in !!
I intend to use it to lift the 7 up for maintenance/work on the car. I am in the process of making up some steel trestle stands to take the whole
car, the lift is just that, it will lift the car up for the stands to go underneath.
It operates as a standard pallet truck up to 200mm lift and will swivel and pull around the loaded pallet on its HD wheels. After 200mm a pair of HD
stabilisers push down onto ground and lift the wheels off whilst stabilising the higher lift. i.e. over 200mm it will not move around.
Once I've got it out of the van I will let you all know if it works out as I intended.
It's not a problem for me if it doesn't, as we need a standard pallet lift in my company anyway.
mandbsheldon
| posted on 10/12/04 at 09:16 AM |
car lift
Is the lift small enough, in its low position to go under the car?
Leigh.
| posted on 10/12/04 at 09:23 AM |
if it goes into a standard pallet, it should slide under aSeven quite nicely!
Like the idea Rob - we have a similar one at work, which could be borrowed on weekends and put to good use.
Nick
mandbsheldon
| posted on 10/12/04 at 10:20 AM |
lift
Yes, but my seven has got tiny wheels
Matthew_1
| posted on 10/12/04 at 10:37 AM |
Thats a top idea - I like it!
But, I'm just thinking that a 550kg car, 800mm in the air, on a base about 600mm wide, it all seems a bit top-heavy?
Have you got plans to modify the pallet truck to make it more stable ?
locoboy
you want to be careful what the forks are going to be pressing on, and be carful it doesnt press in the ally floor, i assume the forks are not long
enough to stick out the other side of the car are they?
Locoboy
ned
| posted on 10/12/04 at 10:40 AM |
another option is to use an engine crane to lift up one end of the car at a time, then slide some steel tresels underneath.
many builders probably have engine cranes already so it could be a minimal outlay soultion!
Ned.
beware, I've got yellow skin
| posted on 10/12/04 at 11:04 AM |
I've never needed to lift my car higher than the jack can lift it. If I need to do anything low down I sit on something while I'm doing
it. You just want a new toy don't you, come on admit it .
[Edited on 10/12/04 by Peteff]
locoboy
| posted on 10/12/04 at 11:13 AM |
Ned.
Chap who used to live behind me runs a hill climb westy and does just that, lifts it a bit at a time and works it up to about a meter off the ground.
Locoboy
Rob Lane
| posted on 10/12/04 at 03:24 PM |
Well here it is. The forks stick through other side of car by 150mm.
What is surprising, is where the centre of the car is. It is very stable and I've shook car around at full lift and it would take a fair bit to
topple it.
This is first ram height :-
Rob Lane
| posted on 10/12/04 at 03:25 PM |
This is full height lift :-
Rob Lane
| posted on 10/12/04 at 03:29 PM |
The whole thing surprised me. The lift is smooth and stable, although quite slow on first lift, speeding up on second lift (Smaller piston). Overall
1 minute to full lift.
The car has a steel floor and it doesn't catch anything. If you had an ali floor it would actually lift the car on the outer steel side rails
anyway.
Bear in mind I only want to lift onto trestles to work comfortably on suspension/brakes or underside.
Cita
| posted on 10/12/04 at 05:22 PM |
You had yourself a bargain i think Rob!
Only problem will be that you'll get used to this tool very quickly!!!!
Spyderman
| posted on 19/12/04 at 07:07 PM |
So do we get to find out where you get these from or is it top secret?
Spyderman
Mikey G
| posted on 19/12/04 at 07:26 PM |
Ive just been searching around and cheapest i can see was £499! i know someone who could do with something like this so where did you find one for
£180?
Mike
Rob Lane
| posted on 19/12/04 at 09:44 PM |
No secret, I got it off ebay but not from a bid. I phoned the firm.
Davpack in Derby. I don't have number to hand but will post it later.
mangogrooveworkshop
| posted on 19/12/04 at 10:29 PM |
Any of these?
Davpack supplies uk packaging materials fast!
... scales, cash registers, carrier bags etc are also stocked at our huge storage facilities
in Derby. ... Davpack supplies packaging materials anywhere in the UK. ...
www.davpack.co.uk/ - 9k - 17 Dec 2004 - Cached - Similar pages
Davpack - Spondon, UK
... My message: Terms of use. Davpack. ... Fax: (01332) 821209. Address. Charlton House East
Service Road Raynesway Spondon Derby DE21 7BF. Map. Spondon, Derbyshire. ...
www.cjdirectory.com/company-4543480.html - 40k - Cached - Similar pages
Spondon, Derbyshire - UK companies
... Davpack, Charlton House East Service Road, Raynesway Spondon, Derby DE21 7BF Save £££
on packaging, cartons, boxes, polythene bags, carriers, stretch film, b ...
www.cjdirectory.com/town-83835.html - 24k - 17 Dec 2004 - Cached - Similar pages
[ More results from www.cjdirectory.com ]
Davpack - Spondon, Derbyshire - UK
... Raynesway Spondon Derby DE21 7BF United Kingdom Map. Spondon companies. Telephone,
fax and web. Tel: (01332) 821200 Fax: (01332) 821209 http://www.davpack.co.uk ...
www.kellysearch.com/gb-company-4543480.html - 34k - Cached - Similar pages
Rob Lane
| posted on 20/12/04 at 08:10 AM |
First one of the results. Davpac, Derby, just off ring road, very easy to find from M1.
That's their ad for the full price version.
I purchased one of the paint peeling long fork jobbies. The paint has not stuck to the forks successfully, so they reduce the price.
Ask for Jo if ringing. (She's nice)
[Edited on 20/12/04 by Rob Lane]
