Author: Subject: Help - which mitre saw?
MikeR
posted on 27/9/15 at 10:50 PM Reply With Quote
Folks,
Looking to buy a mitre saw. Its a bit of a 'want' purchase rather than a desperate need which means my requirements are a bit wooly. I'm after a compound sliding mitre as I think that will give me the most flexibility in years to come. Being a cheap ass northerner I don't want to spend anything - yet want something reliable and accurate. I'm sort of down to the following two saws which aren't really comparable.
So whats the collective wisdom of the forum?
http://www.axminster.co.uk/makita-ls1018l-260mm-compound-mitre-saw- with-laser
or
http://www.amazon.co.uk/Evolution-Rage3-DB-Multipurpose-Double-Bevel/dp/B006BRVQ9K/ref=sr_1_34?ie=UTF8&qid=1443394116&sr=8-34& keywords=mitre+saw
Being 150 quid cheaper I like the idea of the rage, but i'm worried about accuracy, life, quality for if I ever do 'nice' stuff and a little about noise (heard a few comments about how loud they are - it would mean I couldn't do anything in the evening as the little uns bed room is facing the garage).
mark chandler
posted on 27/9/15 at 11:16 PM Reply With Quote
I have one of these
210mm saw
It has been really good, nice repeatable cuts and has chomped through nails stuck in wood with ease.
In hindsight probally should have gone for its bigger brother
255mm saw
[Edited on 27/9/15 by mark chandler]
joneh
posted on 28/9/15 at 07:17 AM Reply With Quote
If your mitre's do not fit, fill the gap with glue and sh1t.
Irony
posted on 28/9/15 at 07:28 AM Reply With Quote
Originally posted by mark chandler
I have one of these
210mm saw
255mm saw
+1 exactly!!
rf900rush
posted on 28/9/15 at 07:29 AM Reply With Quote
I bought a small rage for cutting metal.
Not very robust or accurate, but at about £50. it is fine for my needs.
Work has a £90 version which is much better.
Try to find reviews on amazon , or find them in a local shop and have a good look at them.
Irony
posted on 28/9/15 at 07:30 AM Reply With Quote
I have one of these
210mm saw
255mm saw
+1 exactly!! I also have a diamond blade for mine. Brilliant! Will easily cut 4 or 5 ceramic tiles at the same time! Or one porcelain tile slowly.
Myke 2463
posted on 28/9/15 at 07:38 AM Reply With Quote
Try this Evolution RAGE3-S 210mm Multipurpose Sliding Mitre Saw B Grade 230v
£55 delivered. I bought B Grade and no marks found, very good. HTH.
Also have 255mm around £100 - £120 sometimes.
[Edited on 28/9/15 by Myke 2463]
Be Lucky Mike.
Smoking Frog
posted on 28/9/15 at 09:44 AM Reply With Quote
If it's a toss-up between those two models I'd go for the Makita as I've never used anything by Rage.
geoff shep
posted on 28/9/15 at 10:09 AM Reply With Quote
Can recommend one of these:
http://www.charnwood.net/shop/product/305mm-double-bevel-mitre-saw-1?cid=169
It's the best saw I have had for accuracy and the quality of cut is superb. The bars come forward, rather than stick out at the back, which means it requires a lot less space behind. It's remarkably good value but the dust collection is poor, but that is something you have to pay considerably more for to get right.
And they are just up the road from you.
Edited to add - I also got a table saw, which is OK for what I wanted originally but all of the constituent parts could be better and the after sales service wasn't great. For the bigger stuff I would definitely recommend axminster power tools - and if you have a lottery win go for Festool every time. The mitre saw however is very good.
[Edited on 28/9/15 by geoff shep]
[Edited on 29/9/15 by geoff shep]
