posted on 28/9/15 at 10:15 AM |
VAG Passat B6 won't start???
Not sure if this is the right place to post, but here goes...
Over the weekend I serviced my B6 Passat 2.0 TDI. Part of which was replacing the diesel filter. Easy job, but now the bugger won't start! I
suspect air in the diesel, but other than filling the filter can with clean diesel (which I'll try tonight) I'm a bit stuck. I've
changed the filter before and never had any issues afterwards with starting it.
Anyone got any suggestions or bright ideas....?
Slimy38
posted on 28/9/15 at 10:37 AM |
I saw something about this in a recent issue of car mechanics, they do need to be primed after installation. You may have just got lucky the first
time round.
I think it's just a case of turning the key to on and not starting it, leave for 30 seconds and repeat 3 or 4 times for things to fill up?
SJ
posted on 28/9/15 at 10:57 AM |
When I changed the diesel filter on my Mondeo I had to hand pump some diesel through in order to fill the filter and pipe. Once this was done it
started fine.
There is a bike valve connection on the Mondeo under the bonnet where you can connect a pump. I used one of the little rubber ball type pumps that
come with a one way valve, and used an old bike pump connector to screw onto the car's fuel circuit.
Stu
[Edited on 28/9/15 by SJ]
ian locostzx9rc2
posted on 28/9/15 at 02:18 PM |
I always fill the filters up with diesel then prime by switching ign on and off for about 10 second intervals
SJ
posted on 28/9/15 at 02:26 PM |
From what I've read that can work, but maybe if you don't get quite enough diesel in there it will fail.
I find it much less messy to put it in dry then prime manually, but I guess that depends on the specific car.
posted on 28/9/15 at 03:17 PM |
Thanks for the feedback gents, much appreciated!
I will fill it tonight and get a mechanic mate to purge the air from the system.
Fingers crossed for a snarly TDI fire up
gremlin1234
posted on 28/9/15 at 04:33 PM |
its VW's Mk2 version of their emissions evasion systems, Zero emission and combined immobiliser
sam919
posted on 28/9/15 at 07:16 PM |
I doesn't seem right, but just keep cranking it over and it will eventually start. I done this the other day to my fathers, and going on advice
from my friend whos runs a successful garage I followed the above and after a minute or two it was fine, don't worry about purging it etc it
will self prime after a while
posted on 29/9/15 at 08:10 AM |
Filled the filter can with diesel and still no go! Mate is going to bring home VCDS system tonight and see if he can see anything going on.
posted on 1/10/15 at 08:49 AM |
Filled the filter can right to the top and cranked it over and over - got it running with pops, bangs and smoke! After a minute it ran OK and now
starts/stops fine, thank god.
Lesson - next time remember to fill the filter can with diesel
posted on 1/10/15 at 08:55 AM |
The starting grin was wider than wide
posted on 1/10/15 at 10:51 AM |
Might also add that I'm selling the car after suffering a head injury and being told I can't drive for 12 months by the oh so smart DVLA!
