posted on 18/10/15 at 12:58 PM |
Sealey VS820 Brake Bleeder = Brilliant Tool :-)
I recently bought a new pressure Sealey brake bleeder to replace my modified Eezybleed, my first job with it was to replace the front to rear brake
pipe, after 2 minutes to set it up and pump up to 12 psi or so the bleeding was accomplished in 15 seconds.
Cost was less than £40
Only negatives are the the resevoir is a bit on the large size and it would be improved by a smaller diameter longer hose to ebable it to be used on
the ground rather than balance on top of the engine.
Link to page in Sealey Web Catalogue
posted on 18/10/15 at 01:46 PM |
Been using one for a while , as you say a longer hose would be better as well as a few different master cylinder caps .
