theconrodkid
posted on 10/11/15 at 07:53 PM |
Super cheap CO meter
after lots of messing around i have devised a super cheap CO meter,ok not 100% accurate but near enough,what you expect for £4 ?.
ordered one similar to this 85C1-V Class 2.5 Voltmeter DC 0-5 Volt Wht Panel Meter
mine is 0-1 volt,connect it to earth and output of lambda sensor and watch the vlotage.
0.45 is 14.7-1 or near enough,up to 1 v is rich,lower is lean so you can twiddle your megasquirt etc and have an idea where you are going .
who cares who wins
pass the pork pies
posted on 10/11/15 at 09:48 PM |
A moving coil meter will almost certainly present too much load to an oxygen sensor, they have very high output impedance. Using a digital multimeter
would work ok, but narrow band sensors are pretty hopeless for setting anything other than a stoichiometric mixture.
theconrodkid
posted on 11/11/15 at 09:06 AM |
i had thought about using a digital meter but watching a needle seemed a lot easier than constantly changing numbers.
anyhow,as i said it works as a guide
who cares who wins
pass the pork pies
DW100
posted on 11/11/15 at 09:21 AM |
Narrow band sensors tend to switch about the stoichiometric point and really only show rich or weak. They do not give a linear output relative to air
/ fuel ratio. This is why if you look at a lambda waveform from a normal tin top the voltage oscillates between around 200mv and 800mv with the ecu
trying to average the readings.
I did build a device years ago with a LED bargraph but gave up as it didn't really gives meaningful readings.
