johnH20
posted on 14/1/18 at 07:04 PM |
Araldite or super glue?
This is a Locost question of a different kind! I have domestic tap in my French holiday home which has failed. The tap is a mixer that utilises
up/down ( on/off ) with rotational side to side ( hot/cold ) movements. This has failed where the lever meets the central spherical control. Needless
to say spares are unavailable. Rather than employ a French plumber to source and fit a replacement tap ( mega Euros ) I am looking to a Locost repair
solution. The lever has failed due to corrosion / fatigue at the attachment to the ball joint where the section is approx. 1 mm thick. The lever is
chrome plated zinc alloy as far as I can tell.
I have cleaned the part with formic acid and used a Dremel to remove all corrosion. My plan is to superglue the two pieces together across the narrow
section and then reinforce with some 1 mm stainless steel plates over the joint. The question is what adhesive should I use for this? Potential issues
include thermal expansion, chemical adhesion as well as shear strength. Answers on a postcard as they say, TIA.
froggy
posted on 14/1/18 at 07:26 PM |
Innotec topfix black , weapon of choice at my garage for gluing anything that gets warm etc , probably loads of similar ones about but it goes off
very quickly and touch wood not had anything fail yet
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
cliftyhanger
posted on 15/1/18 at 08:11 AM |
Can you not replace the tap yourself? The monobloc taps are available from £15 upwards (but buy a decent branded one, still cheap especially off ebay
etc or £40ish from screwfix/toolstation)
Fitting is straightforward, especially if you spend a fiver on a set of tap box spanners to get to the awkward to access nut. A deep socket set may
well do the trick, the nuts are usually 8-11mm and from what I have seen virtually everything is fitted with screw-in flexi hoses.
posted on 15/1/18 at 08:26 AM |
C'est un job pour la JB weld n'est pas? ![](/images//smilies/bigsmile.gif)
Mash
posted on 15/1/18 at 11:04 AM |
x2, buy a tap here, take it over there, fit it, job's a good un
Even if you have to do a bit of "locost" to make it fit, you'll still end up with a better tap....
