DorsetStrider
posted on 23/1/05 at 12:00 AM |
Nuts
Anyone know where I can get a tool to remove hub nuts, the big fuckers in the centre of the wheel hubs? I don't really wanna pay a fortune for
something thats only likely to be used a total of 8 times (twice on each wheel)
Who the f**K tightened this up!
mangogrooveworkshop
posted on 23/1/05 at 12:03 AM |
four times only..... its a angle grinder first
posted on 23/1/05 at 12:38 AM |
41mm
Laser tools 1/2" drive about £5.
big_wasa
posted on 23/1/05 at 10:51 AM |
Best bet would be a 3/4 breaker bar and the correct socket for the job .Have a look around the locall second hand shops I picked up a full
metric/imperial combo set for £20. Would give you hand but you 300 miles away
The hub nuts even make my good quality 24" 1/2 breaker bar flex to much.And have sheared a cheaper one.......
wilkingj
posted on 23/1/05 at 11:27 PM |
I did it this way.. Dead Easy..
Tight Nut Problem Solver.
Remember One is Left Hand Thread. Other is RHT. Look carefully at the bit of thead protruding.. And get them back on the right sides as well.
[Edited on 23/1/2005 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
Avoneer
posted on 24/1/05 at 12:15 AM |
Three cuts with an angle grinder and then smack it with cold chisel - I did a previous post in this section about this - 5 minutes for both sides.
Pat...
