aksman
posted on 4/12/20 at 05:49 PM |
Oil Catch Cans
I'm sold on the benefits of crankcase ventilation for an A Series 1275, but... I've done my research and I am still uncertain about which
option to choose.
I'm not averse to buying new when required, but I prefer to buy used when feasible, so...
OPTION 1
I see plenty of cars using crankcase breather filters and no oil catch tank.
There is a view that oil can be flung onto the filters, blocking them and making the ventilation worse?
OPTION2
I see plenty of oil catch cans that appear to be an empty vessel with 2 or 3 pipes leading who knows where.
There is a view that this is bad practice as there needs to be a mesh filter at the top to contain the oily vapour down below, keeping it separate
from the top which vents to atmosphere via a filter?
Also, it seems impossible to identify whether a used catch can has a mesh filter or not, apart from when it is known brand and model?
OPTION 3
Brand new oil catch can with mesh filter in the top?
Your opinions / experience / recommendations would be much appreciated
TIA
steve m
posted on 4/12/20 at 07:50 PM |
Mine was an empty Fosters can, that mainly consisted of white foamy water, taken from the rocker box, and PCV valve take off
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Dingz
posted on 5/12/20 at 01:34 PM |
A bike drink bottle and cage, simple fixing. Bit more expensive than an empty can though
went on and on.
jacko
posted on 5/12/20 at 06:22 PM |
Mine was a spray gun canisters with a small filter on top
Look I my photo. Archives
Jacko
steve m
posted on 5/12/20 at 07:48 PM |
You can buy bike drink cans in the pound shop, not sure how much they cost though
aksman
posted on 6/12/20 at 11:44 AM |
Jacko
Neat job ![](/images//smilies/smile.gif)
aksman
posted on 6/12/20 at 12:30 PM |
No problems with oily fumes from no filter? ![](/images//smilies/smile.gif)
aksman
posted on 6/12/20 at 12:34 PM |
Nice and Locost
No vent to atmosphere?
Or was it a closed system drained back into the sump?
aksman
posted on 6/12/20 at 12:36 PM |
They're 1 pound ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Dingz
posted on 6/12/20 at 03:11 PM |
The pipe goes into the bottle with a bit of foam sponge around the tube at the opening.
went on and on.
aksman
posted on 6/12/20 at 04:04 PM |
Sounds simple and effective. Cheers
[Edited on 6/12/20 by aksman]
aksman
posted on 6/12/20 at 04:28 PM |
So far no-one seems to see any benefit from using an aftermarket can
Which is good if I go down the Locost route because the money saved can be spent on something else
My primary concerns are letting the engine breathe and not putting oily fumes back into the inlet manifold or the engine bay.
The question is: "does an aftermarket can do anything that a Locost can can't?" ![](/images//smilies/shocked.gif)
posted on 7/12/20 at 03:44 PM |
Exactly what I used. As a cyclist I already had bike water bottles and bike water bottle holders so it only cost me my time.
[img] [/img]
[Edited on 7/12/20 by nick205]
Angel Acevedo
posted on 8/12/20 at 04:08 PM |
Metal Scrubie would work well as filter.
Mass of metal cools the air/oil mist and causes oil to drop.
As it will always be saturated in oil, even non stainless will work and last OK.
HTH.
