Chris_R
| posted on 6/3/05 at 07:37 PM |
Not bad for a days work
Decided to build an engine crane instead of buying or renting one. Though it would be a bit of fun and I'd have something to show for it.
I've prolly put in about 7 hours over the weekend and it looks like this so far.
Anyone know how to rate it's capacity without buggering it?
[Edited on 6/3/05 by Chris_R]
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
omega 24 v6
| posted on 6/3/05 at 08:16 PM |
Don't know about capacity but i built one years ago and used a hyd pump and ram from a leyland bison (double acting ). It folds up flat (unlike
yours) and when upright it is located with a 1/2 inch bolt at the base. It has i am told by a borrower lifted the complete front of his mgb gtv8 clean
off of the ground. Just remember the longer the jib the more force will be applied to any pivot points. So 1/2 ton at 1mtr is the same as 1/4 ton at 2
mtrs
Northy
| posted on 6/3/05 at 08:26 PM |
My dad built one for work, when the H&S guy saw it, he asked "how oftern is that tested?".
My dad replied, "Every time we use it!"
Graham
clbarclay
| posted on 6/3/05 at 08:27 PM |
I prefer my engine hoist to have a little more reach and capacity.
Very useful for not just lifting front ends, but also whole cars. Makes moving shells with no wheels left on very easy.
Ben_Copeland
| posted on 6/3/05 at 09:09 PM |
Chris.. very nice
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
NS Dev
| posted on 7/3/05 at 08:13 AM |
yes, I used to use one of those when I was at the farm, twas a Manitou but the effect was the same!
Now have a diy engine crane, knocked up in an evening where I used to work, was quick because we had a CNC plasma/gas profiler (twin head) and I did
all the plates/gussets etc on that! On mine the legs just slot in and out of boxed sockets to make it smaller for transport. I also had a hand pump
from an old big square baler to hand and a selection of rams!
I used to work for Vicon Ltd (formerly Greenland UK ltd and SKH ltd) an agricultural engineering/design company, in their prototype dept.
As for the rating, who knows, and who cares! It lifts a (smallish) tree stump out of the ground without too much difficulty, and the front end of an
Opel Manta wasn't too much for it!
clbarclay
| posted on 7/3/05 at 07:59 PM |
The other benefit is as a portable hydraulic press. Just stick a palet fork where you need it and proceed to raise the front of the machine of the
ground.
Not as much force as a big hydraulic press (about 3 to 4 tonnes) but can staighten big frames without dismantling.
Chris_R
| posted on 7/3/05 at 09:07 PM |
Think a press will be the next project. Not gonna buy any heavy plant though.
clbarclay
| posted on 7/3/05 at 10:09 PM |
I forgot to say, not only can you move your own cars about, you can also move other peoples. Last time any one parks blocking your drive way.
Hows the hoist comming on, any more photos?
[Edited on 7/3/05 by clbarclay]
Chris_R
| posted on 7/3/05 at 10:58 PM |
nah, not yet. work all week and garage is 12 miles away. Will be the weekend before I can have another go.
clbarclay
| posted on 10/3/05 at 11:02 AM |
Rateing a hoists max capacity
To rate the crane dec ide on what its going to lift. In this case it looks like you only want it to lift car engines so 250kg will be plenty, and if
you've built the carne anything like a production crane this should be about right. If in dought build the hoist stronger with more
triangulatrion.
Load the carne up with 275kg (250 plus 10% extra) and if the crane lifts it, you know it is good for 250kg.
Stamp 250kg on the crane as a maximum capacity.
When designing a hoist etc. they will test them to destruction but all cranes/hoists/lift trucks that are to be sold, they build them and test them to
there max load + a safety margen.
If it passes then you know its good and if it fails then be glad it failed on a test load and not when you have a hand (or worse) under the load.
[Edited on 10/3/05 by clbarclay]
Chris_R
| posted on 13/3/05 at 06:52 PM |
Managed to get a little done this weekend. The jack perch is almost done, but does need a bit of tweeking.
Ben_Copeland
| posted on 13/3/05 at 07:35 PM |
Looking good mate
Certainly a beast !!!
Ben
Roadster
Chris_R
| posted on 13/3/05 at 07:45 PM |
Hope it works.
clbarclay
| posted on 13/3/05 at 07:47 PM |
What hydraulics (rams, pumps etc.) are you using?
Chris_R
| posted on 13/3/05 at 07:53 PM |
Prolly a 6 tonne bottle jack. should do the trick, it'll be cheap as chips and will fit snuggly in the press that's next on the list.
jollygreengiant
| posted on 16/3/05 at 05:27 PM |
Personally I'd use sheep and trainers.
clbarclay
| posted on 16/3/05 at 05:44 PM |
Using (and abusing) sheep is a baaa...d idea.
