Author: Subject: how to make a rivnut tool??
tks
posted on 8/3/05 at 03:47 PM Reply With Quote
any one a idea how to make a good and simple rivnut tool??
TKS
flak monkey
posted on 8/3/05 at 03:55 PM Reply With Quote
Shouldnt be difficult with access to a lathe (if you want different sizes). If you only want an M6 one,...it even easier....
Would this work?
A collar with a threaded bar through it. On one end, thread for rivnut. Other end a nut. Screw rivnut onto empty end, upto the collar. Then tighten the nut on the other end to crust the rivnut. Undo the nut, unscrew the stud, and you have one inserted rivnut...
Ahh dammit...see crappy pic...
Sera
http://www.motosera.com
DaveFJ
posted on 8/3/05 at 04:06 PM Reply With Quote
Have a look on Dave jenkins' web site....
Dave
white130d
posted on 8/3/05 at 04:08 PM Reply With Quote
easy peasy
put the rivnut in the hole, Thread a nut onto a bolt of the same size, screw the bolt into the rivnut with a washer between the nut and the rivnut. Holding the bolt with the appropriate sized wrench (spanner for you accross the pond) loosen the nut (so it pushes against the washer/rivnut) and it will draw the rivnut up.
Make Sense?
David.
"There's only 2 things that money can't buy, and that's true love and home grown tomatos" Guy Clark
sgraber
posted on 8/3/05 at 07:57 PM Reply With Quote
I made a short video of a very simple riv-nut tool made from bits of scrap laying around my garage. Worked well for the limited number of riv-nuts I had to install.
http://newtier.vo.llnwd.net/o1/misc/graber/videos/DIYRivnut.mpg
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
chunkielad
posted on 8/3/05 at 10:03 PM Reply With Quote
Man - that's a great vid for something so simple!!
I need to come over and see your build - if a rivnut gets this much attention what has the car had?
