mookaloid
posted on 23/6/05 at 04:33 PM |
Look what I just bought
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4557563649
Mark
mookaloid
posted on 23/6/05 at 07:46 PM |
so no-one interested then?
flak monkey
posted on 23/6/05 at 07:51 PM |
Good stuff Let us all know how you get on with it!
Sera
http://www.motosera.com
mookaloid
posted on 23/6/05 at 08:03 PM |
will do
Jon Ison
to get the best out of it you want some thin shim/tin type material, just lift the wheel enough too slide the shim under too confirm its off the
ground, any higher and you run the risk of unsettling the suspension enough too give you false readings as you move around the car, remember the car
really needs to be on a level surface too.
mookaloid
posted on 23/6/05 at 08:14 PM |
thanks Jon,
Good info
Mark
mangogrooveworkshop
posted on 23/6/05 at 10:51 PM |
Doesnt the driver need to be in the car as well?
posted on 24/6/05 at 12:58 AM |
YIP! Or ballast to equivalent weight!
[Edited on 24-6-05 by Hellfire]
ayoungman
posted on 24/6/05 at 08:00 AM |
When will you set up the tool sharing scheme ? ???.........so we can all borrow it !!!!!!
"just like that !"
mookaloid
posted on 24/6/05 at 09:21 AM |
That will be quite a bit then
mookaloid
posted on 24/6/05 at 09:24 AM |
Interesting point, How does everyone feel about loaning their tools out?
Mark
Snuggs
posted on 24/6/05 at 10:22 AM |
I'd lend my tools to anyone that needs them.
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
ayoungman
posted on 28/6/05 at 01:38 PM |
Its all to do with trust. I lend tools out on the basis of "how likely am I to seeing it again"......and when will it be returned.
I think we have all probably lost tools over the years.
"just like that !"
Jon Ison
posted on 28/6/05 at 04:40 PM |
fair point, i lent my front wishbone jig out over 2 years ago, not seen it since,
if your reading this can i have it back
posted on 28/6/05 at 06:08 PM |
If I lend mine out I usually go with them. I lose too many that way.
