Browser
posted on 12/9/05 at 04:28 AM |
Lapping plate
A long-shot type thread, but does anyone know of anyone who has a cast iron grooved lapping plate sat about that never does owt and they would not cry
to see the back of for a few beer tokens? Best size would be about 16-18" long by about 10-12" wide. Anyone?
omega 24 v6
posted on 12/9/05 at 11:31 AM |
had one and it was always full of cyl heads.
It was motor driven as well just stick the head on and check every 20 mins untill dark grey all over. A fecking beatifull job evewry time.
Hope you get what your looking for mate
owelly
posted on 15/9/05 at 10:19 PM |
What job is it for? I use 1/2" thick plate glass for small jobs.
http://www.ppcmag.co.uk
Browser
posted on 16/9/05 at 01:43 PM |
Lapping the mating face of a cylinder head would be the biggest it'd have to do. I've used glass before but found it tended to go out of
true too easily. Not tried plate glass though, hmmm.
posted on 16/9/05 at 05:24 PM |
Try searching for a surface plate, think that is what you need.
Avoneer
posted on 18/9/05 at 07:47 AM |
What's a "lapping plate" please?
Thanks,
Pat...
posted on 18/9/05 at 09:17 AM |
at a guess, for polishing stuff flat?
SixedUp
posted on 18/9/05 at 09:31 AM |
My (possibly flawed) understanding is that a "surface plate" is a flat, inert surface that is used as the baseline for precision
engineering measurements. The accuracy of the flatness can be truely extraordinary - down to a few wavelengths of light for some applications.
A "lapping surface" is a similarly flat and hard surface but with fine grooves in it that allow (with the addition of grinding powders)
objects to essentially be ground (actually "lapped" ) against it, resulting in a nice flat surface on the object you are lapping.
I guess the usual use for the likes of us would be to ensure very good mating surfaces between things like cylinder heads and blocks.
Richard
[Edited on 18/9/05 by SixedUp]
omega 24 v6
posted on 18/9/05 at 09:36 AM |
Sixed up your 100 % right in your statement mate.
Avoneer
posted on 18/9/05 at 01:08 PM |
Cheers.
So basically a posh, very fine and accurate "file".
Pat...
Rorty
posted on 19/9/05 at 05:51 AM |
I used to use the front screen from an old telly to lap my BSA cylinder heads on.
Cheers, Rorty.
