Author: Subject: 1/4" BSP Thread Cutting Tap
andyharding
posted on 24/11/05 at 03:20 PM Reply With Quote
I'm helping my little bro build a CO2 powered spud gun for his A level Physics coursework.
Any suggestions where I can get a 1/4" BSP tap to cut a thread in the barrel so I can plumb in the CO2 lines?
Also, I haven't quite figured out how to fasten airlines to my pub CO2 bottle so any suggestions there will also be helpful.
P.S. I'm fitting a 10 bar safety valve to the system so he doesn't blow himself up
NS Dev
posted on 24/11/05 at 04:03 PM Reply With Quote
pretty much any tool shop!
a good bet is always cromwell tools,
www.cromwell.co.uk
when I connected my co2 bottle up to my welder, I used a pub pressure regulator, screwed a hydraulic fitting into the reg, drilled the hydraulic adaptor, then soldered a piece of 1/4" copper hydraulic tubing into it.
JonBowden
posted on 24/11/05 at 05:00 PM Reply With Quote
Ok, I must be thick, but what's a spud gun and how do I make one ?
Jon
andyharding
posted on 24/11/05 at 05:13 PM Reply With Quote
1) A cannon that shoots potatos:-
2) Go to Google and search Potato Cannon
Kissy
posted on 25/11/05 at 07:16 AM Reply With Quote
I'll look in the garage tonight - you can borrow it for as long as you need if I have one.
owelly
posted on 25/11/05 at 09:21 PM Reply With Quote
http://rswww.com/
Very good for pneumatic fittings. Use the push-in type with plastic pipe.
http://www.ppcmag.co.uk
JonBowden
posted on 27/11/05 at 10:15 AM Reply With Quote
Ok, I get the idea now - I think I'll need one for next summer
Jon
andyharding
posted on 27/11/05 at 12:00 PM Reply With Quote
Thanks for the offer on the tap but I managed with out.
http://klug.co.uk/videos/MVI_6892_vert_trim.avi
